Link loss forwarding
Antonio_1_2
does Cisco support "Link loss forwarding" on one of its platforms?
Is there maybe any other similar feauture ( i.e. like BFD over ethernet) which could do the same thing?
foe example:
LAN1---cisco1-----layer2_NETWORK---cisco2--- LAN2
some feature which could detect failure somewhere in a layer2 network between cisco1 and cisco2 and
then bring down ports toward LAN1 and LAN2.
Thanks in advance,
A.
Giuseppe Larosa
Hello Antonio,
you should look for CFM Connectivity Fault Management according to metro ethernet forum standards. 802.1ah Ethernet OAM and CFM
It  comes in two flavors link level fault management  or logical level fault management ( roughly single Vlan level EVC in MEF terms).
see
http://www.cisco.com/en/US/docs/switches/metro/me3400/software/release/12.2_60_ez/configuration/guide/swoam.html
CFM over EVC on ES linecards
http://www.cisco.com/en/US/docs/routers/7600/install_config/ES40_config_guide/es40_chap4.html#wp1709601
Hope to help
Giuseppe
Giuseppe Larosa
Hello Antonio,
see
Hope to help
Giuseppe
Thank you very much Giuseppe.
A.
