LISP and IGP interaction in the Wan Edge
anazarenko
Is it possible to make a mutual redistribution between LISP and IGP for a specific Instance/VRF tenant on the Wan edge router?
I want to use LISP on the WAN side and VRF-aware IGP on the LAN side and too lazy to make static LISP mappings on PITR.
Philip D'Ath
I don't know the answer, but I wouldn't think so.  The whole point of LISP is that the location and "IP address" are independent.  Redistribution from LISP into something local like RIP would make them immediately dependent again.
I found a solution: {ipv4 | ipv6} route-export site-registration to populate RIB with null routes on MS, then it's possible to redistribute them into IGP.
