load balance problem
hazemsabry
i have to connections on router 2600 i configured eigrp to load balance, they worked well for some times then after a while i found that load balancing is not working
even though CEF is enabled on both interfaces.and i put this command ip load share-per packet. also it is not working
note
when i type the command show ip eigrp neigbour
i found the two routes but still no load balancing.
the traffic is always going through one interface,traffic goes throgh the other interface only when i shutdown the first one
Hi.
You check the bandwith value on the interfaces ?
The values need to be the same.
The input trafic is balanced ?
What kind of service are you using ?
Best Regards.
bandwidth value on both interfaces is 2048.
and it is vpn connection
