Load Balancing between two ISP in Cisco 881 router
Ibrahim Bhuiyan
I have two ISP connection. I need to do load balance by using these two ISP in Cisco 881 router. Is it possible to configure in Cisco 881 router? If yes the what will be the configuration? Please share the configuration.
Mark Malone
what way is your current circuits setup as in terms of routing what protocol if any are you using, you can easily do it with 2 default routes pointing to each next hop , and set cef share load balancing but if you have critical sensitive applications changing the cef can effect them, also can be done easily with BGP if that's what your using , and another option is pfr
ip route 0.0.0.0 0.0.0.0 1.1.1.1
ip route 0.0.0.0 0.0.0.0 1.1.1.2
https://www.cisco.com/en/US/products/hw/modules/ps2033/prod_technical_reference09186a00800afeb7.html
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipswitch_cef/configuration/15-mt/isw-cef-15-mt-book/isw-cef-load-balancing.html
