12-17-2013 08:28 AM - edited 03-04-2019 09:53 PM
Hello all,
I have dual acces routers connecting to dual node ISP,and we have a two firewall operating on mode Active /standby.
to configure the loadbalancing and loadsharing over the two routers, we have configured the GLBP between the two routers ( ASR) and we have configured the default route to the virtual ip adresse of GLBP from the Firewall
You can find attached the architecture
During the test, the traffic goes always over one router ( wehave tested the tracroute from more than 4 PC on the lan to multiple destination on the wan)
The GLBP is configured on routers :ASR1 and ASR2
The Virtual IP is .10
Default route on the active FW to the .10 (VIP)
thanks,
12-17-2013 09:18 AM
GLBP load balances per client but you only have one client ie. the firewall so it will only go via one router.no matter what load sharing method you use.
Alternatives -
1) you could use MHSRP ie. 2 HSRP groups and then configure 2 default routes on the firewall pointing to both
or
2) just don't run any HSRP/GLBP and just have use the routers physical addresses as the next hops so again you would configure 2 default routes. You would need to track the routes on the firewall in case a route goes down.
Jon
12-20-2013 02:05 AM
I have tried to to configure 2 statique default route on the firewall too the two routers, the routers have the same AD/metric.
I see on the routing table of the firewall that the two routes are instaled.
the traceroute test are ont OK .
i will try to configure ospf : one area between routers and the firewall, and do the same test.
12-20-2013 04:35 AM
Could you give a bit more detail ie. what were you seeing when you did the traceoutes ?
Jon
