load balancing
westcare
We have three facilities. Two of whitch are connected directly to each via DS3. We are working to provision a 2nd DS3 that will connect to the same two facilitied to each. However the 2nd DS3 will be using seperate routes and will also be going through 3rd router at a third facilities. Looking for suggetions on setup. We'd like to load balance across all links. Thanks.
thisisshanky
Level 11
Level 11
It would be nice to see a simple network diagram if you can put that together on MS paint or visio.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
All routers are in place. Only the links going through the 3rd facility are being installed.
