Load Sharing
halilsanif
I am looking for Cisco device (router) that can do load sharing for my company. Can somebody give suggestion which device should we use for best performance.
mohammedmahmoud
Level 11
Level 11
Kindly clarify your needs and topology, any Cisco router can provide load-sharing, but to best address your solution we need more details.
HTH,
Mohammed Mahmoud.
Kindly also describe, what you mean by "load sharing". I have seen so many different perceptions as to what load sharing is or should achieve that it will be helpful to understand your concept of load sharing.
Regards, Martin
OK. I will clarify more details and discuss in the same topic
