LoadBalancing on the 2 HQ routers to all the branches
ievalleyccie
                 |---HQ1(R) -------SP  -------- To 200 branches
ASA -------
                 |---HQ2(R)--------SP  ---------To 200 branches
My customer has HQ site with 200 branches,
In  the HQ there is an ASA which connected to 2 HQ routers and each HQ  router connected to the SP with one link only (default GW) and the SP  router is connected to the 200 Branches .
I need to configure  LoadBalancing from the HQ site to all the branches but I don't know what is the best method should i use (SLA or BGP between HQ and SP or  DMVPN )
Pls addvise
Reza Sharifi
fb_webuser
Level 6
Level 6
You can try load-sharing with BGP like Sharifimr said.
If you want to go further you can try PfR, it´s dificult to configure, but you have many options to tune.
check the doc wiki
http://docwiki.cisco.com/wiki/PfR:Home
Posted by WebUser Pedro Seabra Ávila from Cisco Support Community App
A common solution is BGP with extended communities tagging the traffic going through the router. By the way, you can just load-share in this way. For load balancing you need devices dedicated to this role or PfR.
Alessio
