loadbalancing
daveporter123
how we can have load balancing in routing protocol as well as in switching network, how many possible method for the load balancing as well as feature for the same technology?
how can i configure loadbalancing in static routes?
and what are the requirememt for loadbalancing in switching network?
dporter
and in EIGRP dont forgot to use the VARIANCE...
dave you can have the basic like perpacket loadbalanicing or per destination loadbalancing...you will get this information form the cisco.com...and yes vlad is also post some good links for the reference...
and in etherchannel you can also have l2 and l3 both...
whenever talking about the load balancing in switch STP: then you can have MST, PVST...
you can also have load balancing with bundaling using the multilink ppp also...which is very nice feature: http://www.cisco.com/en/US/tech/tk713/tk507/technologies_configuration_example09186a00800a3b7a.shtml
you can have CEF loadbalncing also but for that first of all you need to read the CEF and for loadbalancing you can have: http://www.cisco.com/en/US/products/hw/modules/ps2033/prod_technical_reference09186a00800afeb7.html
HSRP and GLBP you can have for loadbalancing as well as High Avaibility option also...
hope all this help you
rate this post if it helps
regards
Devang
vladrac-ccna
Level 5
Level 5
Load balancing.
Hello Dave, that's "easy" to answer (kidding).
L2 loadbalancing, I believe this can only be done using spanning-tree and multiple-vlans, and with etherchannels.
with STP, If you have 2 uplinks, 1 vlan would be fwd in 1 link, and 2nd vlan would be fwd in the 2nd link.
check:
Introduction to VLAN Load Balancing Between Trunks
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a00800ae96a.shtml#intro_vlan
for etherchannel:
http://www.cisco.com/warp/public/473/4.html
Understanding EtherChannel Load Balancing and Redundancy on Catalyst Switches
For layer 3:
first hop redundancy
HSRP: configure 2 groups (2 virtual IPs) and set a group of host with gateway 1, and another set with gateway 2.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/hiap_c/ch20/haiphsrp.htm
GLBP
Load balancing is achieved with up to 4 gateways on the same subnet , sharing the same IP but with different virtual macs.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/hiap_c/ch20/haipglbp.htm
Server loadbalancing:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fipr_c/ipcprt1/1cfsflb.htm
TCP Loadbalancing with NAT:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/hiad_c/ch20/ntbaddrs.htm#wp1048769
Routing Loadbalancing:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094820.shtml
Loadbalancing "in hardware"
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/120newft/120limit/120s/120s21/pplb.htm
For static routes, you just need to create 2 statements:
ip route IP mask gate1
ip route IP mask gate2
and use maximum-paths (in some routing protocols that dont do equal-cost load balancing per default).
I hope this is a start point for you,
if it helps, please rate this post.
Vlad
regards
Devang
