Can Cisco 1721 Router support 2MB Leased line?
saravanen.g
Hi guys,
We're using a Cisco 1721 router with WIC-1T connected to a 256kb leased line. We're going to upgrade to 2MB leased line. I'd like to know whether this router can support upto 2MB.
Thanks in advance.
spremkumar
Level 9
Level 9
I have seen Cisco 1721 with WIC-1T handling 2Mbps LL.
And i dont feel you will hve some probs getting it conncted or getting it on working mode..
But if you are planning anything inline with VPN then better think off for enough memory on the box.
regds
spremkumar
Level 9
Level 9
regds
Hi! Thanks for your reply. I will not be configuring any VPN for this link, so it should be ok.
Thanks again :)
in addition to the other post, you also might want to check the data sheet for the 1720/21 (scroll down to the bottom where it says 'WAN Interface Specifications (Optional)':
Cisco 1721 and Cisco 1720 Modular Access Routers
Data Sheet
http://www.cisco.com/en/US/products/hw/routers/ps221/products_data_sheet09186a00800920ec.html
HTH,
GNT
