Local account configure for backup if DUO 2FA failed
pltidjon
Please I need help after I have configured DUO on Cisco Router 4200, my local account is not working
login as: admin1
Keyboard-interactive authentication prompts from server:
| Password:
| Invalid User
End of keyboard-interactive prompts from server
Access denied
| Password:
R1#conf t
R1(config)#aaa new-model
R1(config)#radius server duoauthproxy
R1(config-radius-server)#address ipv4 10.117.1.51 auth-port 1812 acct-port 1813
R1(config-radius-server)#key GFSUPERSECRETKeY!11!!
R1(config-radius-server)#timeout 60
R1(config-radius-server)#exit
R1(config)# aaa group server radius duoauthproxy
R1(config-sg-radius)#server name duoauthproxy
R1(config-sg-radius)#end
R1(config)#aaa authentication login radius-dap group duoauthproxy local-case
R1(config)#line vty 0 4
R1(config-line)#login authentication radius-dap
R1(config-line)#end
R1(config)#aaa authentication login default group radius local
R1(config)#aaa authorization exec default local
pieterh
what do you means with local account not working?
NB! AAA will only fall back to local if the aaa server is unreachable or throws another error
not if the account does not exist or 2FA fails !
index.html (cisco.com)
! Note: Authentication attempts will NOT continue down a method list if a ‘fail’ response
is received, only if an error is received, e.g. if the server is down.
aaa authentication login <authen-exec-list> group <adminAAAgroup> local-case
! Define a AAA authorization method list for exec sessions to a AAA server, with local
fallback in case of loss of communication with the remote AAA servers
