Local loop and remote loop in Leased lines
kiranrokkam
Frequent Visitor
Frequent Visitor
Can any one explains me what is local loop and remote loop in leased line circuits
peterledwidge
Level 5
Level 5
loop back testing can be done to check a leased line for faults.
A local loop would be either a software or hard loop on the NTU/Modem/Martis node in your premises.
Useful for checking your local cable and router interface.
A remote loop is the same except it is done on the NTU/Modem/Martis node at the remote end.
This verifies a path though the network into the remote site as far as the NTU/Modem/Martis node.
Looping can be done both ends if necessary to uncover any problems
to indicate if they are on the local / remote site or within the network.
I know why loopback used I want to know local loop back in leased line .
Is it Between CSU and Router or Between CSU and Telco ?
Is Remote loop back means CSU in one to CSU in other end ?
I just want to confirm ..
Thanking you
Local would be between the router and on site CSU/NTU.
Remote is via the telco network.
Depending on which part of the world your in the CSU/NTU is the demarc point of the Telco.
