logs for internet
eddie.sardinha
Hello All,
What can we check on an ASA 5515x if the ISP went down for a few seconds?  Is there a log for that?
Julio E. Moisa
You should have logging configured but you will see the failure if the interface to the ISP device was down  otherwise you should create a SLA to monitor remote IP address like 8.8.8.8 because the problem could not be originated on the next hop device.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
