Looking for appropriate router
kevinnnguyen
Hi all,
I'm looking for a router under $500 which connect 3 different networks together.
I have an network application running on a laptop. I plan to have my laptop communicate with 3 different networks. I think a router is the device I need.
Anyone know a router model that fits my needs.
John Blakley
You should probably look at the Cisco 800 series. The model numbers with W (like 871W) has wireless also. The default license only supports two VLANs though.
The link below shows that the 871 series supports up to four:
http://www.cisco.com/en/US/prod/collateral/routers/ps380/ps6200/prod_qas0900aecd8028a982.html
--John
HTH, John *** Please rate all useful posts ***
