ERROR: No system memory detected CISCO 1721
alberto.orden
Hi to all,
I have this message in the router ->
System Bootstrap, Version 12.2(7r)XM2, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 2003 by cisco Systems, Inc.
ERROR: No system memory detectå
Need some help,
Best regards,
Alberto
Edison Ortiz
Was this router working previously?
The error is self-explanatory, the router is unable to find the system memory.
You will need to open the router and verify the Boot ROM is properly seated, if properly seated - you will need to order a replacement Boot ROM as it's faulty.
Check out this URL for further information on Boot ROM location
http://www.cisco.com/en/US/docs/routers/access/1700/hardware/notes/1720btrm.html
HTH,
__
Edison.
