LoRaWAN interface on Cisco 809 router
theomarinescu
Hello guys,
I have the following:
  • Cisco 809 router (IR809G-LTE-GA-K9), with IP Base, Data and Security licenses (permanent)
  • LoRaWAN interface module and its software (IXM-LPWA-800-16-K9 & SW-IXM-LPWA-K9)
  • IoTFND device license (LIC-IOTFND-LORAW)
Following the document linked below, I succeeded in configuring the router so it leases a DHCP address to the LoRaWAN interface and the Virtual-LPWA interface goes up:
http://www.cisco.com/c/en/us/td/docs/routers/access/800/829/software/configuration/guide/IR800config/VLPWA.html
However, I don't understand where I am supposed to get the Actility Thingpark LRR software that will act as the LoRa forwarder firmware and the crypto public key the document refers to:
IR809(config)#interface virtual-LPWA 1
IR809(config-if)#lpwa packet-forwarder public-key flash:lrr-1.4.24.pubkey
IR809(config-if)#lpwa packet-forwarder firmware flash:lrr-1.6.11-ciscoms_config.cpkg auto-install if-not-installed
Also, what is the IoTFND license for and where must it be applied ?
I successfuly updated the devices to the latest available software/firmware versions.
Any ideas ?
Thank you !
Edit: added some "show" commands:
IR809#show virtual-lpwa 1 modem info
ModemImageVer : 1.0.06
BootloaderVer : 20160830_cisco
ModemAgentVer : 1.02
SerialNumber : FOZZZZZZZZZ
PID : IXM-LPWA-800-16-K9
UTCTime : 09:36:31.707 UTC Sun Feb 12 2017
IPv4Address : 192.168.1.1
IPv6Address : none
FPGAVersion : 48
TimeZone : EET
LocalTime : Sun Feb 12 11:36:31 EET 2017
ACT2 Authentication : PASS
IR809#
IR809#show virtual-lpwa 1 packet-forwarder info
PublicKeyStatus : Not Installed
FirmwareStatus : Not Installed
PartnerID : ----
IR809#
theomarinescu
Look here for the answer (thanks to Patrick Grossetete):
https://communities.cisco.com/thread/78440
ixm-lpwa-800-16-k9 Has gateway already  lorawan server and is it programmable?.
the guide is not clear:
www.cisco.com/c/en/us/products/collateral/se/internet-of-things/datasheet-c78-737307.html
Maria Jose
