Low Bandwidth Over WAN Interface
Jeffrey Simon
I have Verizon FIOS 150/65 service.  I recently upgraded my router from the stock Actiontec router provided by Verizon to a Cisco 3845.  After the upgrade my up and down speeds are peaking at about 55Mbit/second.  Prior to installing the 3845 I was maxing out the service with full 150/65 with sustained speed tests.  I tried another Cisco router as well and I am getting the same results.  As soon as I go back to the Actiontec the speed increases again.  I did notice that i have quite a few collisions incrementing on the interfaces and I believe my configuration is more than likely to blame.  I have done as much troubleshooting as possible but I am not finding what is limiting the throughput.  My CPU is bored almost 100% of the time, even with heavy traffic traversing the router.  My memory is also bored.  I thought a fresh set of eyes on the problem may shed some light...
Since the CPU is remaining low I do not believe the router is forced to process these packets in software.
I have attached two images of my 24 hour usage (5 minute increments) of both CPU and WAN facing interface...
My current interface config is:
edge3845a#show run int gi0/0
Building configuration...
Current configuration : 363 bytes
interface GigabitEthernet0/0
ip address dhcp
no ip proxy-arp
ip flow ingress
ip nat outside
ip virtual-reassembly in drop-fragments
logging event subif-link-status
load-interval 30
duplex auto
speed auto
media-type rj45
no cdp enable
end
See below output showing collisions:
edge3845a#show int gi0/0
GigabitEthernet0/0 is up, line protocol is up
  Hardware is BCM1125 Internal MAC, address is 0024.c4b9.e1b0 (bia 0024.c4b9.e1b0)
  Internet address is 72.68.75.157/24
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive set (10 sec)
  Full Duplex, 1Gbps, media type is RJ45
  output flow-control is XON, input flow-control is XON
  Last input 00:00:00, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 second input rate 777000 bits/sec, 77 packets/sec
  30 second output rate 46000 bits/sec, 59 packets/sec
     338341298 packets input, 590212818 bytes, 0 no buffer
     Received 4 broadcasts (0 IP multicasts)
     0 watchdog, 4294899676 multicast, 0 pause input
     181774919 packets output, 3635425020 bytes, 0 underruns
     0 output errors, 3758022391 collisions, 1 interface resets
     0 unknown protocol drops
     0 babbles, 4294705023 late collision, 0 deferred
     2 lost carrier, 0 no carrier, 0 pause output
edge3845a#show controllers gigabitEthernet 0/0
Interface GigabitEthernet0/0 (idb 0x692D67D0)
Hardware is BCM1125 Internal MAC (Revision A3)
  network link is up
  Config is Auto Speed, Auto Duplex
  Selected media-type is RJ45
  SFP is not present
MAC Registers:
ds->rx_all_multicast = 0x0
  mac_hash_0_0 =   0x0000000000000000
  mac_hash_1_0 =   0x0000000000000000
  mac_hash_2_0 =   0x0080000400000000
  mac_hash_3_0 =   0x0000000000000000
  mac_hash_4_0 =   0x0000000000000000
  mac_hash_5_0 =   0x0000000000000000
  mac_hash_6_0 =   0x0001000000000000
  mac_hash_7_0 =   0x0000000000000000
  mac_admask_0 =     0x0000FFFFFFFFFFFF, mac_admask_1  = 0x0000000000000000
  mac_cfg =          0x000000C8000A0176, mac_thrsh_cfg = 0x0000080400087804
  mac_vlantag =      0x0000000000000000, mac_frame_cfg = 0x05F4400000280200
  mac_adfilter_cfg = 0x0000000000000F28, mac_enable    = 0x0000000000000C11
  mac_status =       0x0000000000000000, mac_int_mask  = 0x00004F0000C300C3
  mac_txd_ctl =      0x000000000000000F, mac_eth_addr  = 0x0000B0E1B9C42400
  mac_fifo_ptrs =    0x05F4400000280200, mac_eopcnt    = 0x000044000F0F0F0F
  MAC RX is enabled  RX DMA - channel 0 is enabled, channel 1 is disabled
  MAC TX is enabled  TX DMA - channel 0 is enabled, channel 1 is disabled
  Device status = 1000 Mbps, Full-Duplex
PHY registers
BCM5461S DETECTED
  Register 0x00:   1000  796D  0020  60C1  05E1  C5E1  000D  2001
  Register 0x08:   4B75  0200  7800  0000  0000  0000  0000  3000
  Register 0x10:   0000  2F00  0000  0000  0000  xxxx  xxxx  xxxx
  Register 0x18:   shdw  871F  0000  FFFF  shdw  shdw  8000  0000
  Shadow Registers for 0x18
        shadow-addr 0x0000 val 0400
        shadow-addr 0x0001 val 0001
        shadow-addr 0x0002 val 0282
        shadow-addr 0x0004 val 0004
        shadow-addr 0x0007 val 7067
  Shadow Registers for 0x1C
        shadow-addr 0x0002 val 0800
        shadow-addr 0x0003 val 0C00
        shadow-addr 0x0004 val 100C
        shadow-addr 0x0005 val 141F
        shadow-addr 0x0008 val 2144
        shadow-addr 0x0009 val 2408
        shadow-addr 0x000A val 2801
        shadow-addr 0x000D val 3410
        shadow-addr 0x000E val 3863
        shadow-addr 0x000F val 3C00
        shadow-addr 0x0018 val 6004
        shadow-addr 0x001A val 6903
        shadow-addr 0x001B val 6C87
        shadow-addr 0x001C val 7000
        shadow-addr 0x001D val 7400
        shadow-addr 0x001E val 78E2
        shadow-addr 0x001F val 7CA8
  Shadow Registers for 0x1D
        shadow-addr 0x0000 val 054F
        shadow-addr 0x0001 val 8800
Internal Driver Information:
  lc_ip_turbo_fs = 0x0, ip_routecache = 0x11 (dfs = 0/mdfs = 0)
  rx cache size = 768, rx cache end = 512
  max_mtu = 1524
  ring sizes: RX = 256, TX = 256
  rx_particle_size: 1536
Rx Channel 0:
  dma_config0 =     0x0010002001000888, dma_config1 =    0x002A000000600029
  dma_dscr_base =   0x000000000DC20C80, dma_dscr_cnt =   0x0000000000000100
  dma_cur_dscr_a =  0x000030000DC66A92, dma_cur_dscr_b = 0x0100000000000000
  dma_cur_daddr  =  0x000100000DC213E0
  rxring = 0x2DC20C80, shadow = 0x692D8C30, head = 118 (0x2DC213E0)
  rx_overrun=0, rx_nobuffer=0, rx_discard=0
  Error Interrupts: rx_int_dscr = 0, rx_int_derr = 0, rx_int_drop = 0
Tx Channel 0:
  dma_config0 =     0x000000000100108C, dma_config1 =    0x00A9000000000010
  dma_dscr_base =   0x000000000DC21CC0, dma_dscr_cnt =   0x0000000000000000
  dma_cur_dscr_a =  0x800000000E5EE12A, dma_cur_dscr_b = 0x00F0000000004603
  dma_cur_daddr  =  0x000000000DC22A30
  txring = 0x2DC21CC0, shadow = 0x692D9064, head = 215, tail = 215, tx_count = 0
  Error Interrupts: tx_int_dscr = 0, tx_int_derr = 0, tx_int_dzero = 0
  chip_state = 2, ds->tx_limited = 0
  throttled = 0, enabled = 0, disabled = 0
  reset=2(init=1, restart=1), auto_restart=2
  tx_underflow = 0, tx_overflow = 0
  rx_underflow = 0, rx_overflow = 0, filtered_pak=0
  descriptor mismatch = 0, fixed alignment = 0
  bad length = 0 dropped, 0 corrected
  unexpected sop = 0
Software MAC address filter(hash:length/addr/mask/hits):
need_af_check = 0
  0x00:  0  ffff.ffff.ffff  0000.0000.0000         0
  0x74:  0  0024.c4b9.e1b0  0000.0000.0000 338362995
  0xC0:  0  0180.c200.0002  0000.0000.0000         0
  0xC0:  1  0100.0ccc.cccc  0000.0000.0000         0
  0xC5:  0  0180.c200.0007  0000.0000.0000         0
Address Filter:
  Promiscuous mode OFF
  Multicast software filter needed: 1
  Exact match table (for unicast, maximum 8 entries):
    Entry 0 MAC Addr = 0024.c4b9.e1b0
    (All other entries are empty)
  Hash match table (for multicast, maximum 8 entries):
    Entry 0 MAC Addr = 0180.c200.0007
    Entry 1 MAC Addr = 0180.c200.0002
    Entry 2 MAC Addr = 0100.0ccc.cccc
Statistics:
  Rx Bytes                444355328899   Tx Bytes                 98888958847
  Rx Good Packets            338362998   Tx Good Packets            181788025
  Rx Multicast                       0
  Rx Broadcast                       2
  Rx Bad Pkt Errors                  0   Tx Bad Pkt Errors                  0
  Rx FCS Errors                      0   Tx FCS Errors                      0
  Rx Runt Errors                     0   Tx Runt Errors                     0
  Rx Oversize Errors                 0   Tx Oversize Errors                 0
  Rx Length Errors                   0   Tx Collisions                      0
  Rx Code Errors                     0   Tx Late Collisions                 0
  Rx Dribble Errors                  0   Tx Excessive Collisions            0
                                         Tx Abort Errors                    0
If you have any thoughts about what the problem may be I would appreciate the feedback.  I am really trying to build on my troubleshooting skills and this is a great opportunity to learn.
Thank you to everyone in advance!
6 Replies 6
Hi Jeffrey,
Collision are sign of duplex mismatch...
Try hard coding your interface to 100 /  Full...
Smitesh
PS: Please rate helpful posts.
Change was made, let's see if it does any good.  I beleive I may have had this hard coded during my troubleshooting process... but I will try it again to confirm.
ip address dhcp
no ip proxy-arp
ip flow ingress
ip nat outside
load-interval 30
duplex full
speed 1000
media-type rj45
no cdp enable
end
This appears to have eliminated incrementing collisions, but the speeds are still exactly where they were.  Any ideas to increase the throughput?
Jeffrey,
I'm doubting the device opposite your cisco, in terms of speed and Duplex.
Can you just  once more confirm speed and duplex on both the devices and preferrable hard code them.
Smitesh
Jeffrey Simon
When I set everything to auto it does auto-negotiate to 1000/full as it should. It also makes sense that the ISP's device is configured correctly since I am getting correct speeds with their router.
Collisions have stopped incrementing completely but it seems to have nothing to do with my bandwidth problem.  Anyone have thoughts as to what could be the culprit?
Thanks!
