lsmpi_io pool low memory Cisco ISR 4321
Hasan AlNahawy
Dears,
as showing below the memory free of lsmpi_io is very low :
Router_X#show memory
                Head    Total(b)     Used(b)     Free(b)   Lowest(b)  Largest(b)
Processor  7F33741EA010   1728098704   232211688   1495887016   679445864   1048575908
 lsmpi_io  7F3373AE81A8     6295128     6294304         824         824         412
and from this command : show platform software status control-processor brief , it is showing that 98% usage of memory .
Load Average
 Slot  Status  1-Min  5-Min 15-Min
  RP0 Healthy   1.00   1.00   1.00
Memory (kB)
 Slot  Status    Total     Used (Pct)     Free (Pct) Committed (Pct)
  RP0 Healthy  3950588  3853448 (98%)    97140 ( 2%)   2259984 (57%)
CPU Utilization
 Slot  CPU   User System   Nice   Idle    IRQ   SIRQ IOwait
  RP0    0   2.90   9.30   0.00  87.78   0.00   0.00   0.00
         1   1.19   1.99   0.00  96.80   0.00   0.00   0.00
         2   0.00   0.00   0.00 100.00   0.00   0.00   0.00
         3  23.22  76.77   0.00   0.00   0.00   0.00   0.00
there is no any high traffic on this router ,
 5 minute input rate 1000 bits/sec, 1 packets/sec
  5 minute output rate 1000 bits/sec, 1 packets/se
this router look like sleeping , but why the memory usage is high like this !!!!!!!
Yes, on IOS XE platforms like ISR 4421, ASR1k and others, there are two memories. One is for linux kernel and the other is for IOS which runs on top of it.
i dont think the software defect that i mentioned is fixed in 15.4(3)S3 release. It is fixed in 15.5. and teh reason you are seeing the utilization of 98% is because of the software defect that i mentioned before. I dont really think you need to worry about it much but again if you have some doubts you can open a TAC case. I am pretty confident that you are hitting that software defect.
Please let me know if you have any further queries.
Vinit
--Vinit
10 Replies 10
Vinit Jain
Could you please check if you have redundancy mode SSO configured on the router. You have a single RP so that config can still cause the system memory to be used up.
--Vinit
Hi Vinit,
Thanks for your reply , there is no redundancy configured on this router as shown below:
Router_X#show redundancy states
       my state = 13 -ACTIVE
     peer state = 1  -DISABLED
           Mode = Simplex
           Unit = Primary
        Unit ID = 48
Redundancy Mode (Operational) = Non-redundant
Redundancy Mode (Configured)  = Non-redundant
Redundancy State              = Non Redundant
     Maintenance Mode = Disabled
    Manual Swact = disabled (system is simplex (no peer unit))
 Communications = Down      Reason: Simplex mode
   client count = 77
 client_notification_TMR = 30000 milliseconds
           RF debug mask = 0x0   .
Could you please share the show version output from the router. Hopefully i can figure out if this is due to a software defect.
I would also like to know, is there any alarm getting generated or if there is any service impact.
The committed percent on the memory is 57%, which doesnt look like much of a concern to me.
Will share further inputs once i have a reply on the above requested.
Vinit
--Vinit
please find attached result for show log and show version command , the router as i said look like sleepy , there is no any load traffic exist , the purpose of this router is for third party connection so just small traffic going though . i observed this memory utilization from my solarwinds tool , the software on this router was released in may 2015 so it is still new .
Hello Hasan
This issue seems to be due to the software defect# CSCuc40262
If your network management tool is raising an alarm for the high memory due to this issue, then you can use the below OID to monitor the memory:
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectInput=1.3.6.1.4.1.9.9.109.1.1.1.1.27
Hope this answers your question.
Vinit
PS: Please mark the question as answered if your query has been answered.
--Vinit
Dear Vinit,
actually i upgrade the router to safeharbor image (isr4300-universalk9.03.13.03.S.154-3.S3-ext.SPA) and still the memory showing utilized , then i follow your comment and i was changed the OID from my monitoring tool with objectInput=1.3.6.1.4.1.9.9.109.1.1.1.1.27 and i start receiving data for the memory as shown in attached file . as per my research I got this conclusion : lsmpi_io , Processor are a two memories in ISR routers, the Router will always show high level for lsmpi_io because this is used by Linux Kernal for control plane while Processor is the standard memory to take care of data traffic.
but the question now : why we need to treat with 98% memory usage as a normal memory usage !!!!!:
Load Average
Memory (kB)
  RP0 Healthy  3950588  3853564 (98%)    97024 ( 2%)   2260344 (57%)
CPU Utilization
  RP0    0   3.30  10.70   0.00  86.00   0.00   0.00   0.00
         1   0.50   1.10   0.00  98.39   0.00   0.00   0.00
         3  22.90  77.10   0.00   0.00   0.00   0.00   0.00
Vinit
--Vinit
thanks for your kind response and support :)
Dear Vinit
We have the same issue with ISR 4431 running on Version 15.5(3)S4a
I have the cisco ISR 4321/K9 router.
the software version on it is Version 15.5(3)S4b. i have this poblem too. what colud be the issue on it ?
Here i attached the show version details and memory details.
Mode = Simplex
Unit = Primary
Unit ID = 48
client count = 81
RF debug mask = 0x0
show memory
Processor 7F82E8166010 1688360784 276622532 1411738252 639707944 1048575908
lsmpi_io 7F82E79631A8 6295128 6294304 824 824 412
Dynamic heap limit(MB) 1000 Use(MB) 0
Load Average
RP0 Healthy 1.01 1.03 1.00
Memory (kB)
RP0 Healthy 3950540 3918376 (99%) 32164 ( 1%) 2512796 (64%)
CPU Utilization
RP0 0 3.30 8.40 0.00 87.68 0.60 0.00 0.00
1 4.30 4.80 0.00 90.80 0.10 0.00 0.00
2 1.10 0.20 0.00 98.70 0.00 0.00 0.00
3 24.40 75.60 0.00 0.00 0.00 0.00 0.00
