LTE Router VPN Solution
chad.campbell
Hey guys,
I have a quick question, I have a Cisco 899 LTE router, and I would like to establish a VPN tunnel with my data center (ASA 5510) and have LTE as a back up solution, what is the best method of accomplishing this? Does the sim card need to have a static IP?
You can  configure Dynamic VPN on the ASA if you do not have a static IP for your 4G, in that case the VPN is always enabled by the remote 899 router.
Hello Robert, thanks for the feedback! How would my primary internet connection fit in, will it only dial up the 4G when necessary?
