MAC ADDRESS ERROR
pramod
I am getting following error when i configure isis on XR device.How to fix please help
RP/0/5/CPU0:133#RP/0/5/CPU0:Jul 9 21:46:06.759 : ifmgr[198]: %PKT_INFRA-LINK-3-UPDOWN : Interface MgmtEth0/5/CPU0/1, changed state to Up
RP/0/5/CPU0:Jul 9 21:46:06.762 : ifmgr[198]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface MgmtEth0/5/CPU0/1, changed state to Up
RP/0/5/CPU0:Jul 9 21:46:06.828 : netio[294]: %ROUTING-CLNS-3-ETHERENCAP : Incorrect MAC address length 0
RP/0/5/CPU0:Jul 9 21:47:08.770 : netio[294]: %ROUTING-CLNS-3-ETHERENCAP : Incorrect MAC address length 0
RP/0/5/CPU0:Jul 9 21:48:08.806 : netio[294]: %ROUTING-CLNS-3-ETHERENCAP : Incorrect MAC address length 0
Giuseppe Larosa
Hello Pramod,
post the router isis config
it looks like it is not able to correctly encapsulate the IS-IS PDU on an ethernet frame.
To be noted also that if you are trying to run IS-IS on a management interface this can be part of the problem you shouldn't use it to route user traffic but only for management
Hope to help
Giuseppe
Giuseppe Larosa
Hello Pramod,
Hope to help
Giuseppe
Hi Giusepped,
The above suggestion resolved my issues!
