Route Leaking!
pramod
I am facing issues with route leaking!I used same configuration for route leaking on devices ASR 1004 and 12K IOS!
The problem is both giving different output!On 12K iam getting expected output on sh ip bgp vpnv4 all labels but on ASR iam not getting.In forwarding table ASR used POP action but in 12K aggregate !How to fix this!
12K#sh ip bgp vpnv4 all labels
Network Next Hop In label/Out label
Route Distinguisher: 200:1 (vrfB)
172.3.3.3/32 1.1.1.1 nolabel/18
172.4.4.4/32 0.0.0.0 33/aggregate(vrfB)
172.5.5.5/32 0.0.0.0 nolabel/aggregate(vrfD)
Route Distinguisher: 300:1
Route Distinguisher: 400:1 (vrfD)
172.4.4.4/32 0.0.0.0 nolabel/aggregate(vrfB)
172.5.5.5/32 0.0.0.0 34/aggregate(vrfD)
12K#sh mpl
12K#sh mpls for
12K#sh mpls forwarding-table
Local Outgoing Prefix Bytes tag Outgoing Next Hop
tag tag or VC or Tunnel Id switched interface
32 Pop tag 1.1.1.1/32 0 Fa8/1 172.1.1.1
33 Aggregate 172.4.4.4/32[V] 0
34 Aggregate 172.5.5.5/32[V] 0
12K#
ASR1004#sh mpls forwarding-table
Local Outgoing Prefix Bytes Label Outgoing Next Hop
Label Label or VC or Tunnel Id Switched interface
16 Pop tag 1.1.1.1/32 0 Fa8/1 172.1.1.1
17 Pop Label 8.8.8.8/32[V] 0 aggregate/PRAMOD_IL
18 Pop Label 7.7.7.7/32[V] 0 aggregate/PRAMOD_IN
ASR1004#sh ip bg
ASR1004#sh ip bgp vp
ASR1004#sh ip bgp vpnv4
ASR1004#sh ip bgp vpnv4 a
ASR1004#sh ip bgp vpnv4 all la
ASR1004#sh ip bgp vpnv4 all labels
Route Distinguisher: 200:1 (PRAMOD_IL)
7.7.7.7/32 0.0.0.0 nolabel/nolabel(PRAMOD_IL)
8.8.8.8/32 0.0.0.0 17/nolabel(PRAMOD_IL)
Route Distinguisher: 400:1 (PRAMOD_IN)
7.7.7.7/32 0.0.0.0 18/nolabel(PRAMOD_IN)
8.8.8.8/32 0.0.0.0 nolabel/nolabel(PRAMOD_IN)
ASR1004#
Giuseppe Larosa
hi giuseppe,
In the bgp routing table i can see route leaking happening..like
vrf B learning vrf D
but in ASR
PRAMOD_IL is learning the same Is this also an expected behaviour?
In both above examples communication happening fine but on in bgp vpnv4 table getting different outputs!
