07-17-2024 08:49 AM
I am looking to run "switch-to-switch" MacSec on a 8300-2N2S-4T2X. The hand off is 1GE-TX. I realise that the onboard TX interfaces do not support MacSec, but could I use a TX SPF (GLC-TE or SFP-10G-T-X) in one of the onboard 10G interfaces to make this work? The opposite end of the link will be an identical 8300-2N2S-4T2X router.
Solved! Go to Solution.
07-20-2024 01:29 AM
apologies that was wrong URL :
check below FAQ :
https://www.youtube.com/watch?v=zahI4F8IYOk
=====️ Preenayamo Vasudevam ️=====
07-17-2024 03:59 PM
MKA is supported on switch-to-host facing links. Host-facing links typically use flexible authentication ordering for handling heterogeneous devices with or without IEEE 802.1x, and can optionally use MKA-based MACsec encryption.
check the limitation here :
07-18-2024 01:43 AM
Hi BB
Thanks for the response, but I am using a 8300-2N2S-4T2X router not a 8340 and I am looking to do switch-to-switch MacSec, not switch-to-host.
07-20-2024 01:29 AM
check below FAQ :
07-21-2024 02:47 AM
Thanks for the updated links. I have read through the notes again and followed the video. There does not seem to be any stated reason that I can't use a TX optic in the 8300-2N2S-4T2X router onboard 10G interfaces, so I am going to go ahead with my purchases on that basis.
