malformed AS_Path if IBGP sessions confederation
balaji_170
Dear all,
intra-confederation labs -
   Ibgp router (R1 ) - propagate updates packets to intra-confederation neighbor (64512) and 64512 - member as sending notification errors to ibgp router R1 - with Malformed AS_Path
   R1   neighborship going down after receiving notification
i dont what exact root cause of this issuse
kindly check attached configuration files of both routers and wireshark traces and expalin it
note:
ios : 7200
9 Replies 9
Ivan Krimmel
Level 7
Level 7
Hi Balaji,
what is the IOS version you're running?
I checked the config:
R1
router bgp 100
no synchronization
bgp log-neighbor-changes
neighbor 4.1.1.1 remote-as 100
neighbor 4.1.1.1 update-source Loopback0
R4
router bgp 64512
no synchronization
bgp confederation identifier 100
bgp confederation peers 64513
neighbor 1.1.1.1 remote-as 100
neighbor 1.1.1.1 ebgp-multihop 2
neighbor 1.1.1.1 update-source Loopback0
I am not sure it is a valid config where you have confederation on one box and pretending to have iBGP on the other.
In the .cap we do see R4 is complaining to invalid AS-PATH, it expects to receive confederation-styled updates. You can either revert these two to a eBGP sesion, or add R1 to the confederation.
HTH,
Ivan.
Few questions on your setup
- Are the two routers forming a intra confederation peers? If so both routers must be must have info on their BGP confederation id,confederation peers etc and there will be a EBGP neighborship between them
- Or is one of the router say R1 is in a different AS 100 and R4 is a router part of a confederation ? If thats the case both the routers must be configured for different AS.
It looks like a config issue as Ivan explained as R4 is in AS 100 and receives an update from a IBGP neighbor but in this case no confederation id is configured. So there comes the confusion for R4
thanks for your reply
kindly below details for my queries
Labs: snap shot - issuse marked also - after adv network in 101.1.0.0/16 in R1 - i absorved fluctuation in R4 and R5
(confederaion)
and i also attached my configuration files of each routers and traces for your reference
> router ios version : 7200
can please verify my configuration and confirm my configuration for confederation is right or not
or cisco ios 7200 defect
I think your config is not good.
You should put R1-R2 in subAS 64512, R3-R4-R5 in subAS 64513 and you could use R3 as RR in this subAS with R4 and R5 as clients but that would save you only one BGP peering in this subAS.
Then you would have 1 intra-confed eBGP peering between R1 and R3.
Gonna pu the configs once I've verified all in GNS3.
Alain.
Hi alain,
My intention-  when  i  created confederation member -AS  (IBGP sessions)  and i advertise networks to it and observing fluctuations in link between Ibgp and Confederation peers
whether all IBGP sessions - should have confederation peers
I don't understand what you mean.
Here is the config for what I suggested above:
R1:
router bgp 64512
neighbor 10.1.1.1 remote-as 64512
neighbor 3.1.1.1 remote-as 64513
neighbor 3.1.1.1 ebgp-multihop 2
neighbor 3.1.1.1 next-hop-self
neighbor 3.1.1.1 update-source Loopback0
neighbor 4.1.1.1 remote-as 64513
neighbor 4.1.1.1 ebgp-multihop 2
neighbor 4.1.1.1 next-hop-self
R2:
ip route 0.0.0.0 0.0.0.0 10.1.1.2
router bgp 64512
network 102.1.0.0 mask 255.255.0.0
neighbor 10.1.1.2 remote-as 64512
R3:
router bgp 64513
bgp confederation peers 64512
neighbor 1.1.1.1 remote-as 64512
neighbor 13.1.1.1 remote-as 64513
neighbor 13.1.1.1 route-reflector-client
neighbor 15.1.1.2 remote-as 64513
neighbor 15.1.1.2 route-reflector-client
R4:
router bgp 64513
neighbor 13.1.1.2 remote-as 64513
R5:
router bgp 64513
neighbor 15.1.1.1 remote-as 64513
It should work this way
Regards.
Alain.
hi  alain
I  agreed with your configuration - it working fine (All IBGP's  - have intra confederation connectivity)
But my intention
In Same AS
One  router R1 AS (100) is having IBGP session with intra-Confederation R4 AS (64512) Member-AS
R1 trying to published routes to R4 (Confed) router received updates it sending notifcation error to R1
(traces i attached in first mail) - for your reference
> whether any specfic configuration required in Confed ( router ) to accept updates
it wonk work as you want it to, in a confederation there are 3 types of BGP peerings: iBGP inside a subAS and intra-confed eBGP between routers in different subASes and finally normal eBGP between a border router in your confed and another AS.
So you'll have to do like I did before: every router must be part of a subAS
Regards.
Alain.
i understood my problem
