07-08-2005 12:57 AM - edited 03-03-2019 09:59 AM
I have configured an E1 controller on a 2801 router. I want to call to a PSTN telephone. I can call, but the weird thing is, that the phone only rings ones. After that the connection is disconnected.
Further is it not possible to call from the same PSTN phone to the phone connected to the router.
There are also some ATA boxes connected to the router, but they do not work either.
Here is a piece of the running-configuration:
network-clock-participate wic 3
network-clock-select 1 E1 0/3/0
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip cef
ip domain name test.nl
no ftp-server write-enable
isdn switch-type primary-net5
voice-card 0
controller E1 0/3/0
framing NO-CRC4
pri-group timeslots 1-4,16
interface FastEthernet0/1
ip address 192.168.0.61 255.255.248.0
duplex auto
speed auto
standby 1 ip 192.168.0.70
standby 1 priority 110
standby 1 preempt
interface Serial0/3/0:15
no ip address
isdn incoming-voice voice
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.0.57
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
logging trap debugging
logging facility syslog
control-plane
voice-port 0/3/0:15
cptone NL
voice-port 0/2/0
compand-type a-law
voice-port 0/2/1
compand-type a-law
voice-port 0/2/2
compand-type a-law
voice-port 0/2/3
compand-type a-law
dial-peer voice 1 pots
destination-pattern .T
fax rate disable
direct-inward-dial
port 0/3/0:15
forward-digits all
dial-peer voice ........ voip
destination-pattern ........
modem passthrough nse codec g711alaw
session target ipv4:192.168.0.67
incoming called-number .
codec g711alaw
fax rate disable
no vad
codec g711alaw
fax rate disable
no vad
dial-peer voice ........ pots
port 0/2/1
telephony-service
max-ephones 24
max-dn 24
ip source-address 192.168.0.70 port 2000
auto assign 1 to 24
timeouts interdigit 3
user-locale NL
network-locale NL
create cnf-files version-stamp Jan 01 2002 00:00:00
max-conferences 4
dn-webedit
time-webedit
transfer-system full-consult
Does somebody know what the problem could be? If you need some extra information, please let me know.
With kind regards,
René
07-14-2005 06:08 AM
Existing router platforms (earlier than Cisco 1800, Cisco 2800, and Cisco3800) contain a limitation. In some situations, such as when you insert WIC(s) out of order, the configuration of one WIC interface can be lost or applied to another WIC interface.
http://www.cisco.com/en/US/products/hw/routers/ps282/products_tech_note09186a008035b051.shtml
