Marking Management Service generated by router itself problem
ctranminh
Hi forum,
I am working on a QoS project. I want to mark some kinds of traffic generated by router itself such as ICMP, syslog, Netflow and SNMP . I intend to mark them as Management Services and as DSCP af32 then put af32 and af31, which I already marked by HTTP services on a Queue. The problem is that when I mark Management Service in an Output Policy-map, the HTTP service also remarked as af32 too. I don't know how to mark those Management services without remark HTTP service, then put 2 markers in same output queue???
I have some commands here to help you understand my problem.
class-map HTTP
match protocol http
class-map Ouput_queue
match dscp af31
match protocol icmp
match protocol syslog
match protocol snmp
Policy-map Mark_http
class HTTP
set dscp af31
Policy-map output_Queue
class Ouput_queue
set dscp af32 ---> Also remark HTTP traffic
bandwidth 256
Plz help me
ctranminh
No one help me???
If you don't understand problem, plz let me know.. I will talk more
cadet alain
Maybe this could work:
  match not class-map HTTP
match dscp af31
match protocol icmp
match protocol snmp
This way HTTP which has dscp AF31 won't be set DSCP 32 but it will be classified as class-default traffic, is this what you wish?
Regards.
Alain
Thanks to cadet alain,
But that 's not what I want. Maybe I should forget this trouble. I must weigh whether marking or queueing those traffics. And in my situation, I think Marking is more important. When marked, the rest of routers will give them a right queue later. Only in one section of network, traffics generated by a router classified in class-default, however those in the other sections will be classified in right class. Therefore, the purpose of QoS is still  acceptable.
Here is my policy-map in Routers
LAN1------(RouterA)-------(RouterB)-------(RouterC)----LAN2
class match-any MANAGEMENT_SERVICE
   match protocol icmp
   match protocol snmp
class-map match-any BUSINESS_TRAFFIC
   match ip dscp af31
   match ip dscp af32
policy-map OUTPUT_POLICY
  class BUSINESS_TRAFFIC
    bandwidth 1024
    random-detect dscp-based
  class MANAGEMENT_SERVICE
    set dscp af32
