Max distance between T1 smartjack and cisco router
starmantwo
What is the max distance allowed between a t1 smartjack and my cisco router dsu/csu using a cat5e cable. Some searches on the web says its 100meters b/c of ethernet. And some says over 100meters b/c its a serial conn NOT an ethernet. Which one is right? thanks
Giuseppe Larosa
Hello Jeff,
max reach of T1 over RJ-48 is 655 feet = roughly 200 meters.
the 100 meters is for ethernet lan.
see
http://www.interprojekt.pl/doc/ras/max800-6000/m6hwinst/cables.htm
T1 can use a similar cable to that of Fast ethernet/ethernet but it uses different modulations and so it has an higher reach (because it is slower )
Hope to help
Giuseppe
