Maybe a routing table entry?
pskipton01
I have a system that has everything on the managment network 172.16.1.0 network gateway 172.16.1.1. I have connected to the system a small Buisness router on the same network but with a gateway 172.16.1.70, It connects to another small business router via IPSec VPN at an offsite location its network is 192.168.5.0. from a server on the 172.16.1.0 network I can connect to 192.168.5.40 Nas device on the other end. However I would like to be able to connect as nas storage from vmware or ISCSI and VMware will nor the server will allow pinging of the network on the other end.
I think it may need an entry in the routing table to tell it to use the 172.16.1.70 gateway whenever it needs to see 192.168.5.0 network. I think this is the solve to my problem, How would this routing be put in the routing table of the server at 172.16.1.25 so that it sees the Nas/ISCSI store at the other end?
pskipton01
Here is a simple network diagram if this helps.
Ok thanks anyway but I found my answers..
