Memory fragmentation
Latchum Naidu
Hi All,
I am getting the below error logs frequently on my one of the 1841 router.
*Nov 19 14:07:10.716: %SYS-2-MALLOCFAIL: Memory allocation of 5196 bytes failed from 0x602A8BE0, alignment 32
Pool: I/O  Free: 53440  Cause: Memory fragmentation
Alternate Pool: None  Free: 0  Cause: No Alternate pool
-Process= "Pool Manager", ipl= 0, pid= 5 -Traceback= 0x60943E34 0x601D9734 0x601DE4B8 0x601DF91C 0x602A8BE8 0x601ED130 0x601ED2C0 0x6152FF00 0x6152FEE4
*Nov 19 14:07:40.713: %SYS-2-MALLOCFAIL: Memory allocation of 5196 bytes failed from 0x602A8BE0, alignment 32
*Nov 19 14:08:10.735: %SYS-2-MALLOCFAIL: Memory allocation of 5196 bytes failed from 0x602A8BE0, alignment 32
*Nov 19 14:08:40.732: %SYS-2-MALLOCFAIL: Memory allocation of 5196 bytes failed from 0x602A8BE0, alignment 32
*Nov 19 14:09:10.750: %SYS-2-MALLOCFAIL: Memory allocation of 5196 bytes failed from 0x602A8BE0, alignment 32
*Nov 19 14:09:40.756: %SYS-2-MALLOCFAIL: Memory allocation of 5196 bytes failed from 0x602A8BE0, alignment 32
*Nov 19 14:09:43.931: %SEC_LOGIN-5-LOGIN_SUCCESS: Login Success [user: admin] [Source: 192.168.100.49] [localport: 22] at 16:09:43 utc Fri Nov 19 2010
*Nov 19 14:10:10.757: %SYS-2-MALLOCFAIL: Memory allocation of 5196 bytes failed from 0x602A8BE0, alignment 32
*Nov 19 14:10:40.755: %SYS-2-MALLOCFAIL: Memory allocation of 5196 bytes failed from 0x602A8BE0, alignment 32
*Nov 19 14:11:10.752: %SYS-2-MALLOCFAIL: Memory allocation of 5196 bytes failed from 0x602A8BE0, alignment 32
Please find the below are the output for further investigation:
#sh proc mem sorted allocated
Processor Pool Total:  190999824 Used:   29224932 Free:  161774892
      I/O Pool Total:   29360128 Used:   29306688 Free:      53440
PID TTY  Allocated      Freed    Holding    Getbufs    Retbufs Process
137   0 2859094816 2858457440     132920          0          0 Crypto IKMP
185   0  273269292  345209228      12972          0          0 SNMP ENGINE
183   0  214553896  214541688      23956          0          0 IP SNMP
  55   0  212616600   11734776      57884 4069173346    6358576 IP Input
   1   0  196088524  199566416     616196          0          0 Chunk Manager
   5   0  137055296  314045036   29859228  180904525 4241561880 Pool Manager
184   0   71938712          0      13016          0          0 PDU DISPATCHER
   0   0   55626520   58264372     187324     360576      72720 *Dead*
   0   0   38547796   10079028   23698708          0          0 *Init*
172   0   29748140    3050132     129964   22147524          0 Per-minute Jobs
169   0   28756268   28837024       9468          0          0 crypto sw pk pro
193   0    5725424    5630808     100664          0          0 IP-EIGRP: PDM
167   0    4169760    4167420      15312          0          0 Syslog
  94   0    2612888   14590056      14500          0          0 TCP Protocols
  33   0    1793756    1315644       9972     397460          0 Per-Second Jobs
  39   0     656064       1272     636792          0          0 USB Startup
177   0     652412     822852       8064          0          0 NHRP
138   0     587768     548348     220636          0          0 IPSEC key engine
  17   0     256876          0     266848     113400          0 EEM ED Syslog
134   0     236956     120368      76004          0          0 Crypto ACL
175 194     163440     124472      51528          0          0 SSH Process
190   0     149156     140224      73108          0          0 RADIUS
  96   0     136580        420      37028          0          0 DHCPD Receive
127   0     127040        428     135584          0          0 Crypto WUI
  79   0     113468          0      73328          0          0 CEF process
  10   0      97160    1093848      10024      18720          0 ARP Input
  51   0      95332       8928       6972          0          0 AAA Server
176   0      94664          0      11444          0          0 SSH Event handle
  76   0      66144          0      76116          0          0 IP RIB Update
  29   0      58352        296      23128          0          0 Net Background
150   0      28188     277032       6972          0          0 AAA SEND STOP EV
141   0      24912          0      37884          0          0 Crypto Delete Ma
128   0      24196      24196       6972          0          0 Crypto Support
  26   0      12584       7124      18252          0          0 Crypto SS Proces
   0   0      12052    2341456      12052          0          0 *Sched*
160   0      11056       1960      16068          0          0 EEM Server
166   0       9956        856      19072          0          0 EEM Policy Direc
164   0       9436       1784      14468          0          0 VLAN Manager
  59   0       5392        196       6972       2268          0 MOP Protocols
194   0       4108          0       7024          0          0 IP-EIGRP: HELLO
   4   0       3348       4148      10124          0          0 Check heaps
   3   0       2480      18184      12988          0          0 Tunnel Security
  48   0       2444        196       9220          0          0 DTP Protocol
123   0       2400       1432       6972          0          0 LOCAL AAA
  16   0       1592          0       8564          0          0 Entity MIB API
131   0       1372        596      13748          0          0 Crypto CA
117   0       1136        196       7912          0          0 URL filter proc
186   0       1072        196      13904          0          0 IP SNMPV6
124   0        956        196       7732          0          0 TPLUS
102   0        940          0      10912          0          0 HTTP CORE
  54   0        788        196       7564          0          0 CDP Protocol
  30   0        584        312      13244          0          0 IDB Work
  81   0        492        156       7464          0          0 L2MM
191   0        488        196       7316          0          0 NTP
  60   0        392        392      12972          0          0 PPP Hooks
118   0        392        392       6972          0          0 Crypto HW Proc
115   0        368        196       7144          0          0 SDEE Management
129   0        284          0      25256          0          0 RPMS_PROC_MAIN
  49   0        196        196       6972          0          0 dot1x
  47   0        196        196       6972          0          0 PI MATM Aging Pr
  57   0        196        196       6972          0          0 TurboACL
  58   0        196        196       6972          0          0 TurboACL chunk
  32   0        196       2548       6972          0          0 TTY Background
  46   0        196        196       6972          0          0 Call Management
  42   0        196        196       6972          0          0 SM Monitor
  38   0        196        196       3972          0          0 Eswilp Storm Con
  50   0        196        196       6972          0          0 AAA Dictionary R
  37   0        196        196       6972          0          0 ESWPPM
122   0        196        196       6972          0          0 LINE AAA
178   0        196        196       6972          0          0 IP Flow Backgrou
  11   0        196        196       6972          0          0 ATM Idle Timer
171   0        196        196       6972          0          0 Compute load avg
  69   0        196        196      12972          0          0 L2TP mgmt daemon
  12   0        196        196       6972          0          0 AAA high-capacit
  71   0        196        196       9972          0          0 EAPoUDP Process
  72   0        196        196       9972          0          0 IP Host Track Pr
165   0        196          0       7168          0          0 DHCPD Database
  74   0        196        196      12972          0          0 KRB5 AAA
  15   0        196        196       6972          0          0 DDR Timers
  31   0        196        196      12972          0          0 Logger
  77   0        196        196      12972          0          0 PPP IP Route
  78   0        196        196      12972          0          0 PPP IPCP
162   0        196        196       6972          0          0 RMON Deferred Se
161   0        196        196       6972          0          0 RMON Recycle Pro
  19   0        196        196       6972          0          0 Serial Backgroun
  21   0        196        196       6972          0          0 SMART
  22   0        196        196       6972          0          0 GraphIt
   2   0        196        196       3972          0          0 Load Meter
  85   0        196        196       6972          0          0 RLM groups Proce
  23   0        196        196      12972          0          0 Dialer event
  87   0        196        196       6972          0          0 SCTP Main Proces
   6   0        196        196       6972          0          0 Timers
  89   0        196        196       6972          0          0 RUDPV1 Main Proc
125   0        196        196       6972          0          0 VSP_MGR
179   0        196        196       6972          0          0 IP NAT Ager
   8   0        196        196       6972          0          0 Environmental mo
174   0        196          0      25168          0          0 tHUB
119   0        196        196       6972          0          0 ENABLE AAA
108   0        196        196       6972          0          0 RBSCP Background
  25   0        196        196      12972          0          0 XML Proxy Client
  97   0        196        196       6972          0          0 Dialer Forwarder
107   0        196        196       6972          0          0 PPP SSS
  99   0        196        196       9972          0          0 Adj Manager
100   0        196        196      12972          0          0 ATM OAM Input
101   0        196        196      12972          0          0 ATM OAM TIMER
106   0        196        196       6972          0          0 PPP Bind
105   0        196        196      12972          0          0 X.25 Background
173   0        164          0       7136          0          0 CEF Scanner
149   0        164          0       7136          0          0 DATA Collector
148   0        164          0       7136          0          0 DATA Transfer Pr
  75   0         76          0      10048          0          0 IP Background
  98   0          0    1652176       6972          0          0 IP Cache Ager
  62   0          0          0      12972          0          0 SSS Manager
103   0          0          0       6972          0          0 RARP Input
111   0          0          0       6972          0          0 DHCPD Timer
109   0          0          0      12972          0          0 L2F management d
104   0          0          0       6972          0          0 PAD InCall
114   0          0          0      12972          0          0 IPS Timer
110   0          0          0       6972          0          0 Inspect Timer
112   0          0          0       6972          0          0 Authentication P
  56   0          0          0       6972          0          0 ICMP event handl
  34   0          0          0       6972          0          0 AggMgr Process
113   0          0          0       6972          0          0 Auth-proxy AAA B
  28   0          0          0       6972          0          0 Critical Bkgnd
  93   0          0      46056      12972          0          0 TCP Timer
  61   0          0          0       6972          0          0 CRYPTO IKMP IPC
  91   0          0          0       6972          0          0 bsm_xmt_proc
  52   0          0          0       6972          0          0 AAA ACCT Proc
  90   0          0          0       6972          0          0 bsm_timers
116   0          0          0       6972          0          0 IPv6 Inspect Tim
  27   0          0          0       6972          0          0 Inode Table Dest
  86   0          0          0       6972          0          0 SNMP Timers
  84   0          0          0       6972          0          0 IP Traceroute
130   0          0          0       6972          0          0 crypto engine pr
  45   0          0          0       6972          0          0 Platform Compact
132   0          0          0       8972          0          0 Crypto PKI-CRL
133   0          0          0       8972          0          0 Crypto SSL
  92   0          0          0       9972          0          0 CES Client SVC R
135   0          0          0       6972          0          0 CRYPTO QoS proce
136   0          0          0       6972          0          0 Crypto INT
  82   0          0          0       6972          0          0 MRD
  20   0          0          0       6972          0          0 RO Notify Timers
126   0          0          0      12972          0          0 encrypt proc
140   0          0          0       6972          0          0 Crypto PAS Proc
  63   0          0          0      12972          0          0 SSS Test Client
142   0          0          0       8972          0          0 Key Proc
143   0          0          0       9972          0          0 Crypto Device Up
144   0          0          0       6972          0          0 Crypto Hardware
145   0          0          0       6972          0          0 Multi-ISA Event
146   0          0          0       6972          0          0 Multi-ISA Cleanu
147   0          0          0       6972          0          0 PM Callback
  88   0          0          0       6972          0          0 IUA Main Process
  83   0          0          0       6972          0          0 IGMPSN
  18   0          0          0       6972          0          0 HC Counter Timer
151   0          0          0       9972          0          0 EEM ED CLI
152   0          0          0       9972          0          0 EEM ED Counter
153   0          0          0       9972          0          0 EEM ED Interface
154   0          0          0       9972          0          0 EEM ED IOSWD
155   0          0          0       9972          0          0 EEM ED Memory-th
156   0          0          0       9972          0          0 EEM ED None
157   0          0          0       9972          0          0 EM ED OIR
158   0          0          0       9972          0          0 EEM ED SNMP
159   0          0          0       9972          0          0 EEM ED Timer
  44   0          0          0       3972          0          0 IGMP Snooping Re
  80   0          0          0       6972          0          0 Socket Timers
  64   0          0          0       6972          0          0 SSS Feature Mana
163   0          0          0       6972          0          0 Syslog Traps
139   0          0          0       6972          0          0 IPSEC manual key
  73   0          0          0       6972          0          0 IPv6 RIB Redistr
  14   0          0          0      12972          0          0 Policy Manager
  13   0          0          0       6972          0          0 AAA_SERVER_DEADT
168   0          0          0       6972          0          0 VPDN Scal
  70   0          0          0       6972          0          0 X.25 Encaps Mana
170   0          0          0       6972          0          0 Net Input
  68   0          0          0      12972          0          0 L2X SSS manager
  67   0          0          0      13032          0          0 L2X Socket proce
120   0          0          0       6972          0          0 EM Background Pr
121   0          0          0       6972          0          0 Key chain liveke
   9   0          0          0      24972          0          0 Crash writer
  66   0          0          0      12972          0          0 VPDN call manage
   7   0          0          0      12972          0          0 OIR Handler
  65   0          0          0       6972          0          0 SSS Feature Time
  53   0          0          0       6972          0          0 ACCT Periodic Pr
180   0          0          0       7028          0          0 IP NAT WLAN
181   0          0          0       6972          0          0 IP VFR proc
  24   0          0          0       6972          0          0 SERIAL A'detect
  43   0          0          0       3972          0          0 IGMP Snooping Pr
  41   0          0          0       3972          0          0 dev_device_remov
  40   0          0          0       3972          0          0 dev_device_inser
187   0          0          0      13028          0          0 SNMP ConfCopyPro
188   0          0          0      12972          0          0 SNMP Traps
189   0          0          0       6972          0          0 NAT MIB Helper
  35   0          0          0       6972          0          0 Token Daemon
  36   0          0          0       6972          0          0 Transport Port A
192   0          0          0      18100          0          0 IP-EIGRP Router
   0   0          0          0     396944          0          0 *MallocLite*
  95   0          0          0      24972          0          0 COPS
                                 58520772 Total
#sh proc mem sort getbufs
   5   0  139553696  316543436   29859228  180904525 4241561880 Pool Manager
172   0   29751740    3053732     129964   22147524          0 Per-minute Jobs
137   0 2859170160 2858532784     132920          0          0 Crypto IKMP
167   0    4172352    4170012      15312          0          0 Syslog
175 194     199444     160476      51528          0          0 SSH Process
183   0  214563320  214551112      23956          0          0 IP SNMP
                                 58520772 Total
#sh proc mem sort holdin
Processor Pool Total:  190999824 Used:   29222932 Free:  161776892
   5   0  140606696  317596436   29859228  180904525 4241561880 Pool Manager
   1   0  196088524  199568464     614148          0          0 Chunk Manager
137   0 2859207840 2858570464     132920          0          0 Crypto IKMP
175 194     222124     183156      51528          0          0 SSH Process
183   0  214564832  214552624      23956          0          0 IP SNMP
167   0    4173216    4170876      15312          0          0 Syslog
185   0  273270472  345210408      12972          0          0 SNMP ENGINE
                                 58518724 Total
Can any one who experienced this issue, please do investigate on this and help me what needs to be done.
Thanks in advance :-)
Naidu.
8 Replies 8
sfaizul
Hi ,
-Memory fragmentation occurs when a process allocates itself a bunch of small blocks of
memory. Then later frees those blocks of memory leaving holes in memory.
-It is called fragmentation because the free portions of memory appear to be made up for a
bunch of small "fragments" separated by a memory that is still allocated.
-The first signs of a memory fragmentation issue is usually a memory allocation error.
syed.
Hi Syed,
Thanks for your response.
Is that situation will cause anything to production?
I thought to reboot in off working hours, is that good sense? If not what should do to free up the memory.
Naidu.
xabrouck
Your router is facing an IO memory leak.  Don't focus on the fragmentation, it's only a side effect of the leak.  The main issue is that you're running out of IO memory and that's why you see MALLOCFAIL in Pool:I/O.
To troubleshoot this, collect 'show buffers'.  Look at which pool is heavily used (high 'total' number), then dump the packets in that pool with 'show buffer pool XXXX dump'.  We'll see what kind of packets are stuck in the buffers.
If you have a recent IOS, you can also use 'show memory debug leak' (will trigger a high CPU for a minute or so).
If you reload, memory will be cleared but we'll lose the information to troubleshoot the problem.
Only reload if you need to restore service quickly.  It won't fix the problem definitely.  The problem will come back later when the memory will be depleted again.
Xavier
Hi Xavier,
Sorry for the delay...
The issue got fixed by reload at that time but it repeated since today morning.
Please find the below required info for troubleshoot and I am running following version in my router "flash:c1841-advipservicesk9-mz.124-19.bin".
#sh buffers
Buffer elements:
     1117 in free list (1119 max allowed)
     6600382 hits, 0 misses, 619 created
Public buffer pools:
Small buffers, 104 bytes (total 50, permanent 50):
     48 in free list (20 min, 150 max allowed)
     197060170 hits, 82363 misses, 0 trims, 0 created
     11333 failures (0 no memory)
Middle buffers, 600 bytes (total 131, permanent 25, peak 139 @ 2w0d):
     129 in free list (10 min, 150 max allowed)
     370711936 hits, 26699 misses, 1966 trims, 2072 created
     12323 failures (0 no memory)
Big buffers, 1536 bytes (total 50, permanent 50, peak 56 @ 2w6d):
     49 in free list (5 min, 150 max allowed)
     58344057 hits, 93533 misses, 32 trims, 32 created
     9128 failures (0 no memory)
VeryBig buffers, 4520 bytes (total 48, permanent 15, peak 126 @ 1w6d):
     47 in free list (46 min, 16 max allowed)
     21535891 hits, 12226015 misses, 9894200 trims, 9894233 created
     71736 failures (17117 no memory)
Large buffers, 5024 bytes (total 4426, permanent 3, peak 4426 @ 02:10:05):
     4426 in free list (4562 min, 1 max allowed)
     68026 hits, 61684 misses, 20146258 trims, 20150681 created
     3710 failures (175327 no memory)
Huge buffers, 55535 bytes (total 30, permanent 30, need 1):
     30 in free list (1 min, 1 max allowed)
     3493 hits, 217 misses, 8 trims, 8 created
     217 failures (1 no memory)
Interface buffer pools:
Syslog ED Pool buffers, 600 bytes (total 150, permanent 150):
     118 in free list (150 min, 150 max allowed)
     481 hits, 0 misses
Header pools:
Header buffers, 0 bytes (total 768, permanent 768):
     256 in free list (128 min, 1024 max allowed)
     512 hits, 0 misses, 0 trims, 0 created
     0 failures (0 no memory)
     512 max cache size, 512 in cache
     423 hits in cache, 0 misses in cache
Particle Clones:
     1024 clones, 0 hits, 0 misses
Public particle pools:
F/S buffers, 256 bytes (total 768, permanent 768):
     0 hits in cache, 0 misses in cache
Normal buffers, 1548 bytes (total 768, permanent 768):
     768 in free list (128 min, 1024 max allowed)
     0 hits, 0 misses, 0 trims, 0 created
Private particle pools:
FastEthernet0/0 buffers, 1552 bytes (total 512, permanent 512):
     0 in free list (0 min, 512 max allowed)
     512 hits, 0 fallbacks
     512 max cache size, 256 in cache
     174966831 hits in cache, 0 misses in cache
FastEthernet0/1 buffers, 1552 bytes (total 512, permanent 512):
     243947361 hits in cache, 0 misses in cache
#sh ver
Cisco IOS Software, 1841 Software (C1841-ADVIPSERVICESK9-M), Version 12.4(19), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 29-Feb-08 18:45 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)T9, RELEASE SOFTWARE (fc1)
BremenRTR uptime is 3 weeks, 1 day, 12 hours, 37 minutes
System returned to ROM by reload at 04:06:40 utc Sun Nov 21 2010
System restarted at 03:14:25 utc Sun Nov 21 2010
System image file is "flash:c1841-advipservicesk9-mz.124-19.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html you require further assistance please contact us by sending email to
export@cisco.com. 1841 (revision 6.0) with 233472K/28672K bytes of memory.
Processor board ID FCZ1037221F
2 FastEthernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
If
Cisco
#sh proc mem
Processor Pool Total:  191063264 Used:   28469700 Free:  162593564
      I/O Pool Total:   29360128 Used:   29301968 Free:      58160
   0   0   38549724   10068032   23700464          0          0 *Init*
   0   0      12052    1275580      12052          0          0 *Sched*
   0   0   30328608   33046472     176212     290268     290268 *Dead*
   0   0          0          0     396868          0          0 *MallocLite*
   1   0   36813708   36314760     505920          0          0 Chunk Manager
   3   0       1592       9132      12972          0          0 Tunnel Security
   4   0       3296      15068      10072          0          0 Check heaps
   5   0 3774760072 3802212796   27569480  339930064  362709604 Pool Manager
  10   0       3052     578040      10024          0          0 ARP Input
  16   0       1620          0       8592          0          0 Entity MIB API
  26   0       7912       3632      18228          0          0 Crypto SS Proces
  29   0      58352        312      23188          0          0 Net Background
  32   0        196        472       6972          0          0 TTY Background
  33   0    4446296    3967076       9972     397460          0 Per-Second Jobs
  51   0      53168       5060       6972          0          0 AAA Server
  54   0        732        196       7508          0          0 CDP Protocol
  55   0   35043692     751588      57968   20653892     476952 IP Input
  59   0        196        196       6972          0          0 MOP Protocols
  76   0     528004     461860      76116          0          0 IP RIB Update
  79   0     103000          0      73328          0          0 CEF process
  93   0          0       4848      12972          0          0 TCP Timer
  94   0    1420808    8873052      14504          0          0 TCP Protocols
  96   0      96120        196      37024          0          0 DHCPD Receive
  98   0          0     469104       6972          0          0 IP Cache Ager
123   0        992       1316       6972          0          0 LOCAL AAA
127   0     126868        440     135400          0          0 Crypto WUI
128   0      11004      11004       6972          0          0 Crypto Support
134   0     111448      61696      76176          0          0 Crypto ACL
137   0 1889136204 1888661820     161136          0          0 Crypto IKMP
138   0     651920     350996     226020          0          0 IPSEC key engine
150   0      14536     141064       6972          0          0 AAA SEND STOP EV
167   0     336640     334280      15332          0          0 Syslog
169   0   18881344   18939524       9468          0          0 crypto sw pk pro
172   0   31875952     172800    1752916   26933366          0 Per-minute Jobs
175 194     114944      81944      45320          0          0 SSH Process
176   0      72052          0      11408          0          0 SSH Event handle
177   0     417892     519468       7996          0          0 NHRP
180   0          0          0       6972          0          0 IP NAT WLAN
183   0  140652952  140641084      24048          0          0 IP SNMP
184   0   47632284          0      12972          0          0 PDU DISPATCHER
185   0  175828208  223461284      12972          0          0 SNMP ENGINE
186   0       1072        196      13848          0          0 IP SNMPV6
187   0          0          0      12972          0          0 SNMP ConfCopyPro
190   0     112124      77400      73184          0          0 RADIUS
191   0        552        196       7328          0          0 NTP
192   0          0          0      18080          0          0 IP-EIGRP Router
193   0    3410496    3315556     101380          0          0 IP-EIGRP: PDM
194   0          0          0       7032          0          0 IP-EIGRP: HELLO
                                 57762260 Total
Please give me the correct resolution to fix this issue permanently...
Naidu.
Hi All,
Can someone give me any suggestions on this....
Thanks in advance.
Naidu.
The leak is apparently in the large pool, please provide:
- show buffer pool Large dump
- show mem debug leak
thanks,
Xavier
Please find the attached files for the same.
Naidu.
This does not look like a buffer leak:
This looks like a misconfiguration.
Do you have lines in your configuraiton like:
buffer large permanent 3
buffer large min-free 4562
buffer large max-free 1
This would cause the symptoms above and would be a misconfiguration
resulting in IO memory issues.
Please capture the 'show run | i buffer'
........Mike
As always mark your question answered when it is.
