Memory upgrade for 2801
alvaroadp
Hello, I am in the need of having more memory on my 2801, I will run BGP on it, and would like it some more room to play with, but the thing is that my local retailer is charging me US$ 2700 for the 256 megs upgrade. That sounds unreasonable to me, so I am thinking third party memory cards. Anyone knows what kind of memory does this router needs? I opened it, and it looks like a regular sodimm (maybe PC133). Any clues? Thanks
5 Replies 5
royalblues
Level 10
Level 10
Not sure whether you can use any third party memory cards.
But i recently upgraded the memory by 256MB for my 2811 router which approx costed about $1600. You might need to check with other vendors as well :-)
But if you just want to run BGP and exchange some routes, it does not require a 256MB memory.
256MB of memory is recommended when you want to have the entire internet routing table. iF that is the case then i would probably go with atleast a 38xx series router.
Narayan
Well I still have not decided how much I will filter, but getting another router at this point is not an option. Perhaps another 128MB would do it then... well anyway, this is the only retailer I have at this moment, small town. I am thinking of giving it a shot with sodimms I have around...
Have a look at this link
http://www.ciscomemoryupgrades.com/cisco-memory-cisco-router-memory-cisco-2800-series-router-memory-2801-router-memory.html
just understabd that cisco may withhold support for the product if they find that the problem is attributed to any third party product
http://www.cisco.com/en/US/products/prod_warranties_item09186a00800b5594.html
Narayan
jerry.mcrae
try memoryx.net for third party cisco memory.
alvaroadp
Just to let you guys know, that I've gone bold and tried with regular sodimm PC133, and it works fine so far.
