Meraki API
NIKHIL M K
Hi Team,
Can we use same Key for multiple purpose? I would like to use same key for Zabbix monitoring and Syslog.
Thank you
Nikhil M K
Enes Simnica
hello @NIKHIL M K Yes, you can use the same key for multiple purposes, but it depends on the context and the type of key.
Now, If u're referring to a pre-shared key (PSK) or API token, and both Zabbix and ur Syslog system support using the same key format (like a shared secret or token), then technically it's possible. However, it's not recommended for security and auditing reasons , because using separate keys allows better tracking and isolation.....
https://www.zabbix.com/documentation/current/en/manual/api/reference/authentication
https://datatracker.ietf.org/doc/html/rfc5424
hope it helps and PEACE!
-Enes
more Cisco?!
more Gym?!
If this post solved your problem, kindly mark it as Accepted Solution. Much appreciated!
ammahend
if you are talking about API key, sure you can use same key for multiple purposes.
-hope this helps-
