Merge 2 ISP serivces in one network
hbaggash
Hello All,
i would like to merge two services into one network please check  below the devices and services i currently have :
Main Network "Lease Line"
- one Public IP
- Huawei Modem
- ASA 5506X firewall & VPN
- Riverbed QOS
- MS350 Layer 3 with two subnets for two buildings
- MS220
- Access Points
secondary Network,"ADSL"
- four ADSL modems for Four Lines each 4MB
- MikroTik 9001+
- Switch L2
 Access Points
Diagram for the Main network
switch L2------Switch L3-------Riverbed QoS-----ASA 5506x---Modem
my Question is how to merge the two networks and split the functions which the Main network will be used for corporate software such SAP, Prism etc.. while the secondary network will be used for browsing
Note: the main network connected via MPLS as a tunnel to our HQ
plese for your Advice in using four ASA with four Public IP or range of Public IP with Loadbalancer
many thanks,
hesham
Hello
My initial thought would be Policy Based routing, but I am not sure that meraki switch supports it, if it does then given the information you have provided then I would look into this as one possible solution.
res
Paul
Kind Regards
Paul
