Method to troubleshoot and solve Network Delay and latency
Ibrahim Jamil
Level 6
Level 6
Hi Guys
What is the best Method to troubleshoot and solve Network Delay and latency , our Branch users are not happy when access APP in our DCs
thanks
Leo Laohoo
balaji.bandi
You need to check full path, what are the network bottle necks
example :
start from Branch to WAN - ?
WAN to DC ?
DC to any specific server ?
BB
Ibrahim Jamil
Level 6
Level 6
what about PRTG with Network Latency sensor
Joseph W. Doherty
First you need to identify the cause of your latency.  The two common causes are congestion on interfaces (such congestion actually more likely to cause drops, which often causes app "latency"), the second cause being distance based latency (also seen, by users, as app "latency").
Once you've identified the cause(s) of latency (and/or drops), you can sometimes remediate the problem.
Of the two principal causes, dealing with distance based latency, can be very difficult, even sometimes impossible, to remediate.
BTW, at an international company, I worked at years ago, this was an on-going issue.  I.e. "what's wrong with the network"; users in same city as DC report application works fine, but those on the other side of the world (literally) report application performance is horrible (to same DC).  (Also, BTW, buying more bandwidth doesn't solve the distance issue.)
