metric in Route-map
antero
what appens to a route being distributed to EIGRP with this route-map
route-map Redistribicao_BGP permit 20
match ip address 11
set metric 0 -1 0 255 1
Antero
Giuseppe Larosa
Hello Antero,
the seed metric should be rejected by IOS CLI as you are attempting to use a seed BW value of zero ( that would lead to a division by zero) and a negative seed delay of -1 ( that would lead to a negative metric but EIGRP metric is an unsigned 32 bit integer).
EIGRP metric =   256 *  [ 10^7/BW* + Sum of delays in tens of microseconds ]
where BW* is the minimum BW on path expressed in kbps and delay is cumulative over delays on path.
I would be surprised if the command is accepted by CLI.
Hope to help
Giuseppe
Hi Giuseppe
The command is accepted by IOS
the purpose is to balance between two router odd networks and even networks.
but the route that are redistributed with this metric are not learned by the eigrp peer.
thanks
Antero
Hello Antero,
you can play on delay and bandwidth but with reasonable values, delay is cumulative
You should be able to use metric sets changing only delay value to achieve desired results
For example:
10000 1 255 1 1500
10000 100 255 1 1500
Hope to help
Giuseppe
