MGX loopback
trinawong
Hi all,
Any good material for checking loopback in MGX?
pkhatri
Level 11
Level 11
What sort of information are you after ? Are you looking at doing physical loopbacks or software loopbacks ? What specific card are you interested in ?
Paresh
Hi Paresh,
Thanks for your reply, I am looking for how to check software loop in MGX. Any good command reference?
You can use the 'addlnloop' command to software-loop the line. Then, use 'dspln' command to verify that it has been set.
Hope that helps - pls rate the post if it does.
Paresh
