Microloop avoidance in SR Cisco IOS XR
Knonley
Hi All,
Kindly support to clarify about MLA behavior.
- How the MLA behavior will get impacted/changed where there is two ISIS event with 5 sec i.e. default rib-update-delay timer 5 sec. Will it get cancelled or another MLA tunnel will be formed ?
- Will the cisco IOS XR 9K support two MLA tunnel for two different destination prefix at the same time from single source node?
- What if first MLA is created for destination A and after 3 sec i.e. before rib-delay-update timer another ISIS event occur will the first MLA will get cancelled or not ? Or another MLA will be created ?
- If the first MLA in topology get cancelled, then another MLA will be created or not ? In short flapping event less than 5 sec.
0 Replies 0
