05-08-2013 05:13 AM - edited 03-04-2019 07:50 PM
Hello together,
for testing purposues i wanted to exchange a running ASA 5510 with a ASA 5505.
I can't get it working so far and i can't see where the problem is, hopefully there is an expert here, i am kinda new to cisco.
I included the running configs from both the ASA 5510 and the new configured ASA 5505.
Thanks alot in advance and for taking the time!
On the running ASA 5510 there is:
one interface for WEB
static IP xx.xxx.xxx.178
route 0.0.0.0 xx.xxx.xxx.177
one interface for INTERN
static IP 172.16.0.1
Network Object
owncloud 172.16.0.4
ext181 xx.xxx.xxx.181
running-cfg for ASA5510
: Saved
ASA Version 9.1(1)
hostname xxxxxxxx
xlate per-session deny tcp any4 any4
xlate per-session deny tcp any4 any6
xlate per-session deny tcp any6 any4
xlate per-session deny tcp any6 any6
xlate per-session deny udp any4 any4 eq domain
xlate per-session deny udp any4 any6 eq domain
xlate per-session deny udp any6 any4 eq domain
xlate per-session deny udp any6 any6 eq domain
interface Ethernet0/0
nameif INTERN
security-level 100
ip address 172.16.0.1 255.255.0.0
interface Ethernet0/1
nameif WEB
security-level 0
ip address xx.xxx.xxx.178 255.255.255.240
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
management-only
nameif management
security-level 100
ip address 192.168.1.2 255.255.255.0
boot system disk0:/asa911-k8.bin
ftp mode passive
dns domain-lookup WEB
dns server-group DefaultDNS
name-server xx.xxx.xxx.177
object network OwnCloud
host 172.16.0.4
object network EXTADR-181
host xx.xxx.xxx.181
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network obj-0.0.0.0
host 0.0.0.0
object network obj_any-01
object-group service DM_INLINE_TCP_1 tcp
port-object eq https
port-object eq www
access-list INTERN_nat0_outbound extended deny ip 172.16.0.0 255.255.0.0 any4
access-list WEB_access_in extended permit tcp any4 object OwnCloud object-group DM_INLINE_TCP_1 log debugging
pager lines 24
logging enable
logging asdm informational
mtu INTERN 1500
mtu WEB 1500
mtu management 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-711.bin
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (INTERN,WEB) static EXTADR-181
nat (INTERN,WEB) dynamic obj-0.0.0.0
nat (management,WEB) dynamic obj-0.0.0.0
access-group WEB_access_in in interface WEB
route WEB 0.0.0.0 0.0.0.0 xx.xxx.xxx.177 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
http server enable
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
telnet 192.168.1.160 255.255.255.255 management
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 172.16.7.1-172.16.7.254 INTERN
dhcpd dns 62.222.18.8 interface INTERN
dhcpd enable INTERN
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
no active
destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
destination address email callhome@cisco.com
destination transport-method http
subscribe-to-alert-group diagnostic
subscribe-to-alert-group environment
subscribe-to-alert-group inventory periodic monthly
subscribe-to-alert-group configuration periodic monthly
subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:0154e95b11502f7732d8ad41f44ffcba
: end
running-cfg from ASA 5505
: Saved
ASA Version 8.4(4)
hostname xxxxxxx
names
switchport access vlan 2
shutdown
shutdown
interface Ethernet0/4
shutdown
interface Ethernet0/5
shutdown
interface Ethernet0/6
shutdown
interface Ethernet0/7
shutdown
interface Vlan1
nameif INTERN
security-level 100
interface Vlan2
nameif WEB
security-level 0
ftp mode passive
object network owncloud
host 172.16.0.4
object network ext181
host xx.xxx.xxx.181
port-object eq www
access-list WEB_access_in extended permit tcp any object owncloud object-group DM_INLINE_TCP_1
pager lines 24
mtu INTERN 1500
mtu WEB 1500
arp timeout 14400
object network cloud
nat (INTERN,WEB) static ext181
route WEB 0.0.0.0 0.0.0.0 46.245.217.177 1
aaa authentication http console LOCAL
http server enable
http 172.16.0.100 255.255.255.255 INTERN
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
telnet timeout 5
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
webvpn
username xxxxxxx password 7JwaBTv0MbD7ctub encrypted privilege 15
parameters
message-length maximum client auto
inspect ftp
inspect h323 h225
inspect h323 ras
inspect ip-options
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
call-home
profile CiscoTAC-1
no active
Cryptochecksum:7a4a1a1d8a636c5f91ab897d201e516f
: end
05-12-2013 12:59 PM
Hello Karsten,
I would suggest to move your thread to [link below] and close discusion here.
https://supportforums.cisco.com/community/netpro/security/firewall
There are guys in firewall section who have done this bilion times and I am sure they will be happy to help you.
Best Regards
Please rate all helpful posts and close solved questions
