Migrating Router Components
stephen.stack
Level 4
Level 4
Hi Guys,
I have just a little exposure to the 7xxx platform of routers, and i need some help with a migration upcoming.
My question is, will the following list of Cards install/ fit and work correctly in a 7304 Router?
PA-FE-TX
PA-GE=
PA-2FE-T
Stephen
========================== http://www.rconfig.com A free, open source network device configuration management tool, customizable to your needs! - Always vote on an answer if you found it helpful
tcordier
The Port Adapters (PA) are for all 7000 series routers. The cards you mention are also usable for the 7304. Check this link: http://www.cisco.com/en/US/products/hw/modules/ps2033/prod_module_series_home.html
HTH, Thomas
