migration from 1760 to router 1841
rashid_ibraheem
Hello dears
kindly,i have the following qoustion regarding migration from (router 1760 and switch 3550 and DHCP server) to (router 1841 with normal hub and switch)
my Qoustion is how the configuration will bebecame ,since its the first time i deal with this router 1841
your support are highly appriacated
note :- the attach file show the past configratio for router and the switch
5 Replies 5
Giuseppe Larosa
Hello Rashid,
configuration of router can be quite similar.
Here the point of attention is the change on the switch part.
You say : >> migration from (router 1760 and switch 3550 and DHCP server) to (router 1841 with normal hub and switch)
if you mean you want to use an unmanaged switch or hub there are some changes needed.
with an unmanaged switch you cannot assume it knows about vlan2 and vlan100 you are currently using.
Or the device can be configured and you can use two vlans, trunk port and vlan subinterfaces as you are doing now or the device supports a single vlan like an hub.
In the latter case you need two unmanaged switches one for current vlan2 and one for current vlan 100.
This requires you to configure two physical ports as the current subinterfaces of the C1760.
you need to go from:
interface FastEthernet0/0.1
encapsulation dot1Q 2
ip address 10.3.2.254 255.255.255.0
interface FastEthernet0/0.2
encapsulation dot1Q 100
ip address 10.200.6.1 255.255.255.0
to
int f0/0
desc to siwtch1
int f0/1
desc to switch2
also notice that you cannot use the voice vlan concept, this means you need to connect PCs to first switch and phones to switch2.
Hope to help
Giuseppe
dear Giuseppe
kindly , i have only one unmanage switch thats right, but i want to get benefit from the 4 ports in 1841 router to operate Voice and Data
thanks
Hello Rashid,
if your C1841 has an etherswitch module installed with 4 ports you can use three for phones and one towards the unmanaged switch, PCs can be connected to the unmanaged switch.
the three ports of etherswitch module can be configured with a data vlan and voice vlan as in a regular standalone Cisco Lan switch
in this case you need to do the following:
a) create L2 vlans on etherswitch module
this may require to enter vlan database config mode
router#vlan database
router(vlan)#vlan 2
                 name datavlan
                 vlan 100
                 name voicevlan
                 apply
                 exit
now you can create SVI, L3 interfaces for vlan 2 and vlan 100
router#config t
int vlan 2
! data vlan subnet here
ip address  ...
no shut
int vlan 100
! voice vlan subnet here
ip address ...
no shut
single ports can be configured as switch ports with
int f0/x
switchport
switchport mode access
switchport voice vlan 100
swtchport access vlan 2
no shut
Hope to help
Giuseppe
Dear Giuseppe
thanks for you replay
your notes was benefit to me ,anyhow VOICE and data are working according to the below configuration
no ip dhcp use vrf connected
ip dhcp pool ASIACELL-data-Pool
   network 10.4.6.0 255.255.255.0
   default-router 10.4.6.254
   dns-server 192.168.163.1 192.168.163.30
   domain-name asiacell.com
   option 150 ip 10.200.128.10
controller E1 0/0/0
channel-group 0 timeslots 1-31
controller E1 0/0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1/0
switchport access vlan 2
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface Serial0/0/0:0
ip address 10.254.2.202 255.255.255.252
encapsulation ppp
interface Serial0/0/1:0
no ip address
encapsulation ppp
interface Vlan1
no ip address
interface Vlan2
ip address 10.4.6.254 255.255.255.0
router eigrp 100
redistribute static
network 10.0.0.0
no auto-summary
end
where I make one DHCP in the router with one subnet(it give ip address for ip phone and pc). And delete V Lan 100 voice
Anyhow my questions now are:-
1-      The above configuration work but how can I return the VLan 100(subnet voice) with the cmd switchport voice vlan 100 since when I try to make separate DHCP pool for voice, the rest fastethernet port go down and data go down the pool was
   ip dhcp Voice-Pool
   network 10.200.130.0 255.255.255.0
   default-router 10.200.130.254
2-      for the first comments from you side :how the configuration will be done if make the DHCPS for voice and data in the router ?and how I can do connect if I using DHCP server for the two unmanaged switch
BEST regards
RASHID
Hello Rashid,
as I've explained you need first to create vlan100 as a L2 broadcast domain.
This can be done or in the vlan database context or in config context this depends on your IOS version and what etherswitch model you have.
For your reference I put the following link about etherswitch configuration in 12.4T
http://www.cisco.com/en/US/docs/ios/lanswitch/configuration/guide/lsw_hwic_ethsw_ic_ps6441_TSD_Products_Configuration_Guide_Chapter.html#wp1046684
Also be aware that vlan database cannot be exited using CRTL-Z but you need to type exit because changes become effective only after apply or exit command
attempting to assign etherswitch ports to a non existent vlan causes the ports to be placed in a disabled state.
So the key point should be to find the correct way to create L2 object vlan100.
Once that this is done all should work.
interface Vlan100 is the L3 object that can be up/up only if L2 object exists.
This creates some confusion sometimes. It is important to see the difference between the two objects.
the second DHCP pool can be created with no problems, remember to exclude router ip address in SVI vlan 100
Hope to help
Giuseppe
