Minimum bootimage for ATA Flash Disk
ccsam
I try to search for minimum requirement for bootimage to bootup IOS from ATA Flash Disk which runs on RSP4/4+ but did not find any?
Thanks.
I did a search on CCO and found the following, not sure if that helps...
Using the Compact Flash Disk
Hardware and Software Requirements
http://www.cisco.com/en/US/products/hw/routers/ps352/products_installation_and_configuration_guide_chapter09186a00802043f2.html#wp1053214
Flash Memory Card Compatibility and Software Prerequisites
http://www.cisco.com/univercd/cc/td/doc/product/core/cis7505/frus/2083flmc.htm#xtocid965
GP
