03-09-2017 07:54 AM - edited 03-05-2019 08:10 AM
Hello
I have a problem with my cisco catalyst 3650 L3 switch (IOS-XE software, software CATK3K_CAA-UNIVERSALk9-M, Version 03.07.04E RELEASESOFTWARE fc1)
I want to configure a routing protocol like ospf or EIGRP but the commands doesn't exists.
you find attached to this an screenshot of my configuration.
thank you in advance.
03-09-2017 09:11 AM
Usually is required an IP Base or IP Services IOS to run routing protocols. Have you tried enabling:
configure terminal
ip routing
Licensing for Cisco Catalyst 3650 Series Switches
The three feature sets available with all Cisco Catalyst 3650 Series Switches are:
● LAN Base: Enterprise access layer 2 switching features
● IP Base: Enterprise access layer 3 switching features
● IP Services: Advanced enterprise layer 3 switching (IPv4 and IPv6) features
The LAN Base feature set offers enhanced intelligent services that include comprehensive Layer 2 features, with up to 255 VLANs. The IP Base feature set provides entry-level enterprise services in addition to all LAN Base features, with 4094 VLANs. IP Base also includes the support for wireless controller functionality (mobility agent and mobility controller role; additional access point license required for mobility controller role), routed access, smart operations, FNF, and so on. The IP Services feature set provides full enterprise services that include advanced Layer 3 features such as EIGRP, OSPF, BGP, PIM, and IPv6 routing such as OSPFv3 and EIGRPv6. All software feature sets support advanced security and MQC-based QoS.
The Cisco Catalyst 3650 Series Switches with LAN Base feature set can only stack with other Cisco Catalyst 3650 Series LAN Base switches. The same applies to IP Base and IP Services as well. A mixed stack of LAN Base switch with IP Base or IP Services feature set is not supported.
Customers can transparently upgrade the software feature set in the Cisco Catalyst 3650 Series Switches through Cisco IOS Software CLI using the right to use (RTU)-based software upgrade process. Software activation enables the Cisco IOS Software feature sets. Based on the license’s type, Cisco IOS Software activates the appropriate feature set. License types can be changed, or upgraded, to activate a different feature set.
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3650-series-switches/datasheet-c78-729449.html
Also this link is useful to know the available features per IOS or device:
http://cfn.cloudapps.cisco.com/ITDIT/CFN/jsp/index.jsp
I remember using the show version can be seen the license.
Hope it is useful
