Modem Autoconfig
trinawong
Modem autoconfig constantly occupied 20% of totall cpu utilization, could you please advise if it could be related to configuration issue?
CCA0001R#sh process cpu | e 0.00
CPU utilization for five seconds: 26%/2%; one minute: 20%; five minutes: 19%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
3 4208 12 350666 20.87% 5.70% 1.33% 1 Modem Autoconfig
CCA0001R#sh run | b line con
line con 0
session-timeout 15
exec-timeout 15 0
escape-character 3
Thank you!
didyap
Level 6
Level 6
For the high cpu utilization issue see the two cases at here
Modem Auto config process stuck and using 2% CPU This bug affects AS5800's and the CPU Utilization for the Modem
Auto configure process is not nearly as high. And Ports staying in Modem Auto configure mode for a long time
This bug was reported for AS5800's and we are not seeing the same symptomsin terms of show user,
as a solution for that disable the auto configure of modem.
Follow the URL for Troubleshooting High CPU Utilization on Cisco Routers which will help you :
http://www.cisco.com/en/US/customer/products/hw/routers/ps133/products_tech_note09186a00800a70f2.shtml
