Modem issue on Cisco 810 router
mohammedrafiq
                   Hi ,
I am trying to enable 4G on router and keep getting unknown modem. Please see debug output and config,any idea where I am going wrong?
*Oct 29 16:59:03.323: TTY0: pause timer type 1 (OK)
*Oct 29 16:59:03.323: CHAT3: Attempting async line dialer script
*Oct 29 16:59:03.323: CHAT3: process started
*Oct 29 16:59:03.323: CHAT3: Asserting DTR
*Oct 29 16:59:03.915: TTY3: DSR was dropped
*Oct 29 16:59:03.915: TTY3: Quickly dropping DTR
*Oct 29 16:59:03.915: tty3: Modem: READY->HASPROC
*Oct 29 16:59:03.915: TTY3: Line reset by "Async dialer"
*Oct 29 16:59:03.915: TTY3: Modem: HASPROC->HANGUP
*Oct 29 16:59:03.915: TTY3: no timer type 0 to destroy
*Oct 29 16:59:03.915: TTY3: no timer type 1 to destroy
*Oct 29 16:59:03.915: TTY3: no timer type 3 to destroy
*Oct 29 16:59:03.915: TTY3: no timer type 4 to destroy.
*Oct 29 16:59:03.915: TTY3: no timer type 10 to destroy
*Oct 29 16:59:03.915: TTY3: no timer type 2 to destroy
*Oct 29 16:59:04.915: TTY3: dropping DTR, hanging up
*Oct 29 16:59:04.915: tty3: Modem: HANGUP->IDLE...
*Oct 29 16:59:09.915: TTY3: restoring DTR.
Success rate is 0 percent (0/5)
TEST-4G#sh run
Building configuration...
WLAN_AP_SM: Config command is not supported
Current configuration : 1758 bytes
! Last configuration change at 17:01:53 UTC Tue Oct 29 2013
version 15.2
hostname TEST-4G
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
chat-script gsm "" "ATDT*99*#" TIMEOUT 20 "CONNECT"
license udi pid C819HG-4G-G-K9 sn FCZ173991QZ
controller Cellular 0
interface Cellular0
ip address negotiated
ip nat outside
ip virtual-reassembly in
encapsulation slip
load-inter0
dialer in-band
dialer idle-timeout 1800
dialer string gsm
dialer-group 1
async mode interactive
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip add
interface GigabitEthernet0
no ip address
shutdown
duplex auto
speed auto
interface Serial0
no ip address
shutdown
clock rate 2000000
interface Vla ip address 10.1.1.1 255.255.255.0
ip nat inside
ip forward-protocol nd
no ip http ser
              no ip http secure-server
ip nat inside source list 100 interface Cellular0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0
access-list 100 permit ip any any
dialer-list 1 protocol ip permit
control-plane
line con 0
logging synchronous
login local
no modem enable
line aux 0
         no activation-character
no exec
transport preferred none
transport input all
stopbits 1
line 3
exec-timeout 0 0
script dialer gsm
modem InOut
no exec
tranport input all
rxspeed 100000000
txspeed 50000000
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
TEST-4G#
0 Replies 0
