modem nat connect cisco router
TimMees60387
I have a problem, I have a modem that is connected to a Cisco router, can I connect remotely via SSH?
M02@rt37
Hello @TimMees60387
Do you check if the modem forward TCP_22 to the internal IP of the cisco router ?
Best regards
Hello
how is the rtr configured and where are you trying to connect to the rtr from?
Kind Regards
Paul
Without static NAT
You can not?
Also some modem have capability to block specific port, check that
MHM
