Modem speed change
alison.hou
I configured aux 0 for my modem speed to 115200 but it kept changing to different speed. is there something I have to do in the modem to fix it?
line aux 0
exec-timeout 0 0
password 7 15135A5D50070E747C26
modem InOut
modem autoconfigure type usrmodem
transport input all
stopbits 1
flowcontrol hardware
speed 115200
RTR_CN#sh line aux 0
   Tty Line Typ     Tx/Rx    A Modem  Roty AccO AccI  Uses  Noise Overruns  Int
*     1    1 AUX  57600/57600 - inout     -    -    -     0      0    0/0      -
Line 1, Location: "", Type: ""
Length: 24 lines, Width: 80 columns
Baud rate (TX/RX) is 57600/57600, no parity, 1 stopbits, 8 databits
Status: Ready, Active, No Exit Banner, CTS Raised, Modem Configuring
  Modem Speed Locked, Modem Signals Polled, Autoconfig Running
Capabilities: Hardware Flowcontrol In, Hardware Flowcontrol Out
  Modem Callout, Modem RI is CD, Modem Autoconfigure
Modem state: Ready
Modem hardware state: CTS* noDSR  DTR RTS
Special Chars: Escape  Hold  Stop  Start  Disconnect  Activation
                ^^x    none   -     -       none
Timeouts:      Idle EXEC    Idle Session   Modem Answer  Session   Dispatch
                never         never                        none     not set
                            Idle Session Disconnect Warning
                              never
                            Login-sequence User Response
                             00:00:30
                            Autoselect Initial Wait
                              not set
Modem type is usrmodem.
Session limit is not set.
Time since activation: never
Editing is enabled.
History is enabled, history size is 20.
DNS resolution in show commands is enabled
Full user help is disabled
Allowed input transports are pad telnet rlogin lapb-ta mop udptn v120 ssh.
Allowed output transports are pad telnet rlogin lapb-ta mop v120 ssh.
Preferred transport is telnet.
Shell: enabled
Shell trace: off
No output characters are padded
No special data dispatching characters
thanks,
brett.harding
Hi Alison,
You can try using the commands rxspeed 115200 and txspeed 115200 but it is more likely caused by the aux port getting the line speed from the modem. The autoconfigure script could be detecting the DTE port speed from the modem configuration. Does the aux port line speed remain at 115200 if you remove the command "modem autoconfigure type usrmodem" and you reconfigure the speed to 115200? If it does, then you will likely need to configure the modem DTE port speed by reverse telneting into the modem and using the AT command set.
Rgds
Brett
