Monitoring Bandwidth in Wan interface
stemond79
Hey guys,
i have a Cisco 1841 with Hwic 1-t (IOS 12.4(15)T12 ).
i want monitoring average load of my HDSL.
How to can i monitoring my bandwith in upload and in download for WAN interface ?
Any help ?
thanks to All
Stefano
mrdogantr
Hi Stefano,
     You can use Cacti (open source rrd tool). or other commercial monitoring tools (Solarwinds, Opmanager ....).
hth
Muammer
Tharak Abraham
Level 3
Level 3
The most easy way to calculate is using a lower "load interval" under the interface.
You can calculate the rate of input and output based on intervals.
I believe 30 secs is the lowest configurable amount.
And rest all is Math..-:)
May not be so accurate but fair enough
The second option is to use tools.
Dear Friend,
You can Monitoring Bandwidth of WAN Interface by MRTG or PRTG.
SNMP configure in your router.
Cheers!!!
