Moving static route to a new CE break the network
khaled alodat
Hi Guys,
I hope you can help.
I've upgrade the CE from 3825 to 3925 but we have a problem .
The router is connecting to an MPLS cloud.
We have 10 static route in the old one which we need to move them to the new router, two of these static route, when I apply them to the new router a lot of drops can been seen, again when i remove them everything wrok normal.
I've check the BGP routing tabe and Im sure the the network is not learned anywhere but the new router .
When I remove the router cuasing the problem, and tray to traceroute the netwrok it send me to the default router in our data center (which mean the the mpls dont know what to do with the traffic-which is good), but again when I add the static route again to the CE everything start to go bad (alot of drops).
blau grana
Level 7
Level 7
Hi Khaled,
Could you upload your topology and config so we can visualize what is going on, thanks.
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
