MPLS and FR
John Blakley
All,
Where does a FR switch sit in relation to a provider's network? Does it sit on the edge or behind a router? If it sits on the edge, how do I keep the customers in a VRF? Do I only map from the customers perspective to the PE router?
Example:
PE1 ----> FR SW ---> Customer 1
                 |________Customer 2
I'm assuming that in the FR switch, I'd have dlci PE1 --> Customer1 and PE1 --> Customer2. Is that all that's required? What about LMI and Inverse ARP? Disable?
HTH, John *** Please rate all useful posts ***
rais
Level 7
Level 7
PE can itself offer Frame Relay encapsulation to CE.
HTH.
