MPLS - BGP question
saquib.tandel
Hi All
Recently we moved Sales-Office from point-to-point link to provider MPLS cloud. HQ already part of MPLS for long time with other branches connected.
Our Data Provider says that our Sales-Office*Q1 are part of MPLS Cloud and protocol is BGP but when we got the configuration it was IP and static routes. It works but are such scenario possible for MPLS? Also the Backup Link Gre over IPSEC starts behaving weird after these changes. I have to shut GRE tunnel to avoid flapping of connection.
ST
9 Replies 9
Giuseppe Larosa
Hello Saquib,
the protocol used within the SP network is always multiprotocol BGP for MPLS L3 VPN service. The protocol used between your router (CE) and the SP router (PE) can also be made of static routes as you have seen in your CE router.
On the SP PE node the static routes pointing to your CE IP address are redistributed in BGP and then propagated as needed on the SP network reaching all the PE nodes serving your other offices connected to the MPLS cloud.
This is a real issue. You have to check if the GRE over IPSec packets are not routed over the MPLS cloud that is something you don't want.
The backup path should use an indipendent path and should not be affected by changes on the primary path,
You may need an additional static route pointing to the backup path to fix this issue.
Hope to help
Giuseppe
thanks Giuseppe
Here is the salesoffice router config, plz tell which routes to add
version 12.4
service sequence-numbers
hostname SO#Q1
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
dot11 syslog
ip cef
ip name-server 172.16.45.150
ip name-server 172.16.45.151
voice-card 0
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
crypto isakmp key passkey123 address 62.238.x.x
crypto isakmp keepalive 10
crypto ipsec security-association lifetime seconds 86400
crypto ipsec transform-set transform esp-3des esp-md5-hmac
crypto map mymap 10 ipsec-isakmp
set peer 62.238.x.x
set transform-set transform
match address ACL
archive
log config
  hidekeys
interface tunnel19
description TUNNEL to HQ-INTERNET-BACKUP
bandwidth 1544
ip address 172.20.1.233 255.255.255.252
ip mtu 1400
shutdown
tunnel source 92.47.x.x
tunnel destination 62.238.x.x
interface FastEthernet0/0
description WAN-Port
ip address 172.16.3.77 255.255.255.248
ip flow ingress
ip flow egress
duplex auto
speed auto
interface FastEthernet0/1
description LAN-PORT
  ip address 172.16.45.1 255.255.254.0
ip flow ingress
ip flow egress
duplex auto
speed auto
interface Serial0/1/0
no ip address
ip flow ingress
ip flow egress
encapsulation frame-relay IETF
frame-relay lmi-type q933a
interface Serial0/1/0.25 point-to-point
ip address 92.47.x.x 255.255.255.252
snmp trap link-status
frame-relay interface-dlci 22
crypto map mymap
interface Vlan1
no ip address
router ospf 2
log-adjacency-changes
redistribute static
network 172.16.0.0 0.0.255.255 area 0
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Serial0/1/0.25
ip route 172.16.100.0 255.255.255.0 172.16.3.78
ip route 172.16.101.0 255.255.255.0 172.16.3.78
ip route 172.16.103.0 255.255.255.0 172.16.3.78
ip route 172.16.103.0 255.255.254.0 tunnel19 200
ip access-list extended ACL
permit ip 172.16.45.0 0.0.0.255 172.16.100.0 0.0.0.255
permit ip 172.16.45.0 0.0.0.255 172.16.101.0 0.0.0.255
permit ip 172.16.45.0 0.0.0.255 172.16.103.0 0.0.1.255
Hi Saquib,
as Giuseppe already said, BGP is a kind of mandatory protocol for MPLS. The whole infrastructure can work properly as long as the ip reachability is satisfied.. Nevertheless, BGP in its different configurations, can to encode many different MPLS information in its updates providing many features that the static routing can't really realise. If you have Core routers pointin to some external ISP(s) you can even avoid BGP sessions as giuseppe was explaining above but if you have MPLS inside your infrastructure you have not really so much choice.... For the GRE tunnel.... just take it away and play with metric and administrative distance.
Hope it helps
Alessio
Alessio / Giuseppe,
looking at the config just removing GRE tunnel and adding higher metric didnt help, can you guide what I am missing more
thanks in advance
ST
HI there,
i would say two things... the first is to add the subnet option to redistribute static below OSPF process
the second is that you are still advertising over the tunnel the network (although with static route
Can't you advertise that link in Ospf and the to change the metric/administrative distance ? Remember that metric is intra-domain and administrative distance is inter-domain...
As a suggestion only i would be more specific when you advertise your route because otherwise you loose control and everything becoms more difficult. If you send me the topology you desire to accomplish i can study a config to propose you.
This should be the command but the idea is called floating static route. If the primary static route goes down this second route with bigger administrative distance will come into play, a bit like you did with the tunnel 19 but with a simple static route
http://www.cisco.com/en/US/tech/tk801/tk133/technologies_configuration_example09186a0080093d6e.shtml
let me/us know
Alessio
thank u for supporting, i attached the current setup layout.
primary path for sales-office19 reaching HQ should be via IPSEC VPN and if internet is down then traffic should pass over mpls cloud
let me know if more information is needed
thanks
ST
Hi Saquib,
try this:
p route 0.0.0.0 0.0.0.0  172.16.3.78
ip route 172.16.100.0 255.255.255.0  Serial0/1/0.25  (longest match is preferred)
ip route 172.16.101.0 255.255.255.0  Serial0/1/0.25
ip route 172.16.103.0 255.255.255.0  Serial0/1/0.25
or this:
ip route 172.16.100.0 255.255.255.0 172.16.3.78 200
ip route 172.16.101.0 255.255.255.0 172.16.3.78 200
ip route 172.16.103.0 255.255.255.0 172.16.3.78 200
Why do you advertise /23 in the static route?
Since it is MPLS VPN layer 2, can't you run OSPF between Office Sales 19 and Office sales 1?
Remeber to change the redistribution command in
redistribute static subnets
Let me know,
Alessio
PS: why are you using OSPF? Wouldn't you prefer to encapsulate different vlan on FastEthernet subinterfaces? and then just static routing? it would be cool if you could run OSPF over the entire WAN!!!
Alessio, let me clear some  points
Data Provider had given BGP config for Sales office 1 and internally we got ospf  but for Sales Office 19 they provided static route config. If you see the initial post it address these query.
If I get you correctly from my original posted config , i would remove the following
no interface tunnel19
no router ospf 2
no ip route 0.0.0.0 0.0.0.0 Serial0/1/0.25
no ip route 172.16.100.0 255.255.255.0 172.16.3.78
no ip route 172.16.101.0 255.255.255.0 172.16.3.78
no ip route 172.16.103.0 255.255.255.0 172.16.3.78
no ip route 172.16.103.0 255.255.254.0 tunnel19 200
/23 is incorrect, it should be /24
after removing the above, will add the static routes you provided
what  you mentioned in 'PS' - not clear. can u help with sample config example
many thanks
ST
Hi Saquib,
just a step at the time ....
ip route 0.0.0.0 0.0.0.0  172.16.3.78
!(longest match is preferred)
no int tunnel 19
end
or if it does not work this:
no int tunnel 19
end
by now leave OSPF in place because i didn't really get why you are using it. It would be great to have the partial routing table:
show ip route static
before and after the changes.  Check this solution before implementing it because i miss some info. I am quite sure anyway that this change can help you.
I think this could work. For the PS i wrote down, i was only thinking that since you can run OSPF as CE-PE protocol, you could manage just one area 0 connecting all your core network offices. But it is very demanding in terms of implementation. Ignore it.
