MPLS Cloud --- Trying to upload the System Images from LMS
Hi Experts,
Kindly let me know that is there any VRF enabled commands are required in order to configuration with Cisco LMS v 3.0. Because i have faced the issues in Tacacs Authentication which required the Per VRF Authentication feature suggested by Cisco TAC. Actually, i am trying to upload/download images from LMS but i am getting fail. I am attaching the Output Files here.
My Mgmt Devices IP's (Lo 50) & server Farm are on the same vrf & can be reach via "ping vrf ABC ip 10.13.3.21 source lo 50"...
Kindly update me on this issue.
Mubasher
Hi Experts,
I really need ur help
Kindly update me on this issue...
Hello Mubasher,
May you post the file configuration of the node / switch ?
If I understood correctly you are trying to access a device via a VRF access link where the LMS serveer is connected.
Are you able to access telnet or ssh to the device using a shell on LMS ?
You may also post this in the network management forum where it is morel ikely to find help on LMS (if something has to be changed on LMS).
Here we are more focused on network devices.
You can find help about the node configuration here
Hope to help
Giuseppe
