MPLS L3 VPN not pinging routes in Route table
wilok
Hi Fellows,
Please i need help, i have been trying to troubleshoot these topology, I created an MPLS VPN (design/ configs attached), but the ISP3R can't ping ISP1R VRF. Everything looks okay with the config.
ISP2R and attached CE can ping ISP1R and attached CE's but ISP3R can't ping across the configured P routers (ISP5R and ISP6R). But the Routes all show up in the Routing tables/ VRF table,
when i use: sh bgp vpnv4 unicast
Please kindly help. I'm doing this on a Cisco VIRL using the IOS XR as the Provider Network and IOSv as the Customer edge.
Attached are the design and config.
RP/0/0/CPU0:ISP1R#sh run
Fri Jul 6 15:14:25.304 UTC
Building configuration...
!! IOS XR Configuration 6.1.3
!! Last configuration change at Fri Jul 6 12:18:53 2018 by CVAC
hostname ISP1R
vrf WILOK
address-family ipv4 unicast
import route-target
450:100
export route-target
450:100
address-family ipv4 multicast
import route-target
450:100
export route-target
450:100
vrf WILSON
import route-target
300:150
450:100
export route-target
300:150
interface Loopback0
ipv4 address 11.11.11.11 255.255.255.255
interface MgmtEth0/0/CPU0/0
shutdown
interface GigabitEthernet0/0/0/0
description INT TO ISP5R G0/0 INT
ipv4 address 10.10.9.1 255.255.255.252
interface GigabitEthernet0/0/0/1
description INT TO ISP6R G0/0 INT
ipv4 address 10.10.10.1 255.255.255.252
interface GigabitEthernet0/0/0/2
shutdown
interface GigabitEthernet0/0/0/3
shutdown
interface GigabitEthernet0/0/0/4
shutdown
interface GigabitEthernet0/0/0/5
vrf WILOK
ipv4 address 20.40.2.1 255.255.255.252
interface GigabitEthernet0/0/0/6
vrf WILSON
ipv4 address 21.21.2.1 255.255.255.252
route-policy ACCEPT
end-policy
router static
vrf WILOK
20.40.0.0/16 20.40.2.2
router ospf 5
router-id 11.11.11.11
area 0.0.0.0
interface Loopback0
router bgp 5500
address-family vpnv4 unicast
neighbor-group PE_ROUTERS
remote-as 5500
update-source Loopback0
next-hop-self
neighbor 22.22.22.22
use neighbor-group PE_ROUTERS
neighbor 33.33.33.33
neighbor 44.44.44.44
vrf WILOK
rd 100:50
redistribute static
vrf WILSON
rd 200:100
redistribute eigrp 40
mpls oam
mpls ldp
mpls label range table 0 16100 16199
router eigrp 40
vrf WILSON
address-family ipv4
default-metric 10000 100 255 1 1500
autonomous-system 40
redistribute bgp 5500
end
RP/0/0/CPU0:ISP2R#sh run
Fri Jul 6 15:16:59.476 UTC
!! Last configuration change at Fri Jul 6 13:25:35 2018 by cisco
hostname ISP2R
vrf WILOK
import route-target
300:150
450:100
export route-target
450:100
interface Loopback0
ipv4 address 22.22.22.22 255.255.255.255
shutdown
description INT TO ISP5R G0/1 INT
ipv4 address 10.10.11.1 255.255.255.252
description INT TO ISP6R G0/1 INT
ipv4 address 10.10.12.1 255.255.255.252
shutdown
shutdown
shutdown
description INT TO WILOKCORP SITE 2
vrf WILOK
ipv4 address 100.150.10.1 255.255.255.252
router static
vrf WILOK
100.150.0.0/16 100.150.10.2
router ospf 5
area 0.0.0.0
interface Loopback0
router bgp 5500
remote-as 5500
next-hop-self
neighbor 11.11.11.11
vrf WILOK
rd 100:50
redistribute static
mpls oam
mpls ldp
mpls label range table 0 16200 16299
end
RP/0/0/CPU0:ISP2R#
RP/0/0/CPU0:ISP5R#sh run
Fri Jul 6 15:18:08.070 UTC
!! Last configuration change at Fri Jul 6 13:19:11 2018 by cisco
hostname ISP5R
interface Loopback0
ipv4 address 55.55.55.55 255.255.255.255
shutdown
description INT TO ISPIR G0/0
ipv4 address 10.10.9.2 255.255.255.252
description INT TO ISP2R G0/0
ipv4 address 10.10.11.2 255.255.255.252
description INT TO ISP3R G0/0/0/0 INT
ipv4 address 11.11.9.2 255.255.255.252
description INT TO ISP4R G0/0/0/0 INT
ipv4 address 11.11.11.2 255.255.255.252
shutdown
shutdown
shutdown
interface GigabitEthernet0/0/0/7
shutdown
interface GigabitEthernet0/0/0/8
shutdown
interface GigabitEthernet0/0/0/9
shutdown
interface GigabitEthernet0/0/0/10
description INT TO ISP6R G0/10
ipv4 address 172.16.16.2 255.255.255.252
router ospf 5
router-id 55.55.55.55
area 0.0.0.0
interface Loopback0
mpls oam
mpls ldp
mpls label range table 0 16500 16599
end
RP/0/0/CPU0:ISP5R#
RP/0/0/CPU0:ISP6R#sh run
Fri Jul 6 15:19:30.604 UTC
!! Last configuration change at Fri Jul 6 13:18:37 2018 by cisco
hostname ISP6R
interface Loopback0
ipv4 address 66.66.66.66 255.255.255.255
shutdown
ipv4 address 10.10.10.2 255.255.255.252
ipv4 address 10.10.12.2 255.255.255.252
description INT TO ISP3R G0/0/0/1 INT
ipv4 address 11.11.10.2 255.255.255.252
description INT TO ISP4R G0/0/0/1 INT
ipv4 address 11.11.12.2 255.255.255.252
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
ipv4 address 172.16.16.1 255.255.255.252
router ospf 5
router-id 66.66.66.66
area 0.0.0.0
interface Loopback0
mpls oam
mpls ldp
mpls label range table 0 16600 16699
end
RP/0/0/CPU0:ISP6R#
RP/0/0/CPU0:ISP3R#sh run
Fri Jul 6 15:20:14.933 UTC
!! Last configuration change at Fri Jul 6 13:26:50 2018 by cisco
hostname ISP3R
vrf WILOK
import route-target
450:100
export route-target
450:100
vrf WILSON
import route-target
300:150
450:100
export route-target
300:150
interface Loopback0
ipv4 address 33.33.33.33 255.255.255.255
shutdown
description INT TO ISP5R G0/0/0/2 INT
ipv4 address 11.11.9.1 255.255.255.252
description INT TO ISP6R G0/0/0/2 INT
ipv4 address 11.11.10.1 255.255.255.252
description INT TO WILOKCORP3 ROUTER G0/1
vrf WILOK
ipv4 address 15.25.35.1 255.255.255.252
route-policy ACCEPT
pass
end-policy
router ospf 5
router-id 33.33.33.33
area 0.0.0.0
interface Loopback0
router bgp 5500
remote-as 5500
weight 32768
next-hop-self
vrf WILOK
rd 100:50
vrf WILSON
rd 200:100
mpls oam
mpls ldp
mpls label range table 0 16300 16399
end
RP/0/0/CPU0:ISP3R#
RP/0/0/CPU0:ISP4R#sh run
Fri Jul 6 15:22:00.065 UTC
!! Last configuration change at Fri Jul 6 12:19:13 2018 by CVAC
hostname ISP4R
vrf WILOK
import route-target
450:100
export route-target
450:100
vrf WILSON
import route-target
300:150
450:100
export route-target
300:150
450:100
interface Loopback0
ipv4 address 44.44.44.44 255.255.255.255
shutdown
description INT TO ISP5R G0/0/0/3 INT
ipv4 address 11.11.11.1 255.255.255.252
description INT TO ISP6R G0/0/0/3 INT
ipv4 address 11.11.12.1 255.255.255.252
description INT TO WILSONCORP2 ROUTER GE0/1
vrf WILSON
ipv4 address 30.31.32.1 255.255.255.252
router ospf 5
area 0.0.0.0
interface Loopback0
router bgp 5500
remote-as 5500
next-hop-self
route-reflector-client
mpls oam
mpls ldp
mpls label range table 0 16400 16499
end
RP/0/0/CPU0:ISP4R#
On R3 you should add "redistribute connected"
vrf WILOK
rd 100:50
vrf WILSON
rd 200:100
6 Replies 6
a.alekseev
Level 7
Level 7
sh mpls ldp neighbor
I have checked earlier, i still could not find the problem.
Using the P routers, here are the outputs.
RP/0/0/CPU0:ISP5R#sh mpls ldp neighbor brief
Mon Jul 9 02:27:33.190 UTC
Peer GR NSR Up Time Discovery Addresses Labels
ipv4 ipv6 ipv4 ipv6 ipv4 ipv6
66.66.66.66:0 N N 00:02:41 1 0 6 0 15 0
11.11.11.11:0 N N 00:02:41 1 0 3 0 15 0
33.33.33.33:0 N N 00:02:41 1 0 3 0 15 0
44.44.44.44:0 N N 00:02:41 1 0 3 0 15 0
22.22.22.22:0 N N 00:02:41 1 0 3 0 15 0
RP/0/0/CPU0:ISP6R#sh mpls ldp neighbor brief
Mon Jul 9 02:27:52.830 UTC
22.22.22.22:0 N N 00:05:08 1 0 3 0 15 0
11.11.11.11:0 N N 00:05:08 1 0 3 0 15 0
44.44.44.44:0 N N 00:05:07 1 0 3 0 15 0
33.33.33.33:0 N N 00:04:21 1 0 3 0 15 0
55.55.55.55:0 N N 00:03:00 1 0 6 0 15 0
RP/0/0/CPU0:ISP5R#show mpls interfaces
Mon Jul 9 02:29:38.012 UTC
Interface LDP Tunnel Static Enabled
GigabitEthernet0/0/0/0 Yes No No Yes
GigabitEthernet0/0/0/1 Yes No No Yes
GigabitEthernet0/0/0/2 Yes No No Yes
GigabitEthernet0/0/0/3 Yes No No Yes
GigabitEthernet0/0/0/10 Yes No No Yes
RP/0/0/CPU0:ISP5R#
RP/0/0/CPU0:ISP6R#sh mpls interfaces
Mon Jul 9 02:29:46.382 UTC
Sh ip  bgp vpnv4 all
from 33.33.33.33 and 44.44.44.44
Hi Alekseev,
Thanks for your quick response, please here is the output. For 33.33.33.33 and 44.44.44.44
RP/0/0/CPU0:ISP3R#sh bgp vpnv4 unicast
Mon Jul 9 08:00:16.086 UTC
BGP router identifier 33.33.33.33, local AS number 5500
BGP generic scan interval 60 secs
Non-stop routing is enabled
BGP table state: Active
Table ID: 0x0 RD version: 0
BGP main routing table version 37
BGP NSR Initial initsync version 20 (Reached)
BGP NSR/ISSU Sync-Group versions 0/0
BGP scan interval 60 secs
Status codes: s suppressed, d damped, h history, * valid, > best
i - internal, r RIB-failure, S stale, N Nexthop-discard
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
Route Distinguisher: 100:50 (default for vrf WILOK)
*>i20.40.0.0/16 11.11.11.11 0 100 0 ?
* i 11.11.11.11 0 100 0 ?
*>i21.21.2.0/30 11.11.11.11 0 100 0 ?
*>i21.21.3.0/24 11.11.11.11 2570240 100 0 ?
*>i21.21.4.0/24 11.11.11.11 2570240 100 0 ?
*>i100.150.0.0/16 22.22.22.22 0 100 0 ?
* i 22.22.22.22 0 100 0 ?
Route Distinguisher: 200:100 (default for vrf WILSON)
* i 11.11.11.11 2570240 100 0 ?
Processed 10 prefixes, 15 paths
RP/0/0/CPU0:ISP4R#sh bgp vpnv4 unicast
Mon Jul 9 08:00:45.524 UTC
BGP router identifier 44.44.44.44, local AS number 5500
BGP main routing table version 31
BGP NSR Initial initsync version 5 (Reached)
Processed 7 prefixes, 12 paths
RP/0/0/CPU0:ISP4R#
vrf WILOK
rd 100:50
vrf WILSON
rd 200:100
I'm lost of words to say thanks.
You made my morning. This solved it.
Thanks greatly.
